I believe SOP is to use plain nuts with internal tooth lockwashers, no safety wire. That's how mine was equipped from the factory.
I used shielded wire for the entire run from mag to switch, using the shield to complete the ground when the switch is in the "off" position. The wire came with Van's wiring kit, but I'm sure Aircraft Spruce or similar would have it too.
