Well, thanks to the builders' websites and the many posts on this forum, I have mananged, with only mininmal previous experience, to complete the fiberglass fairing of the canopy and it looks good enough to pass QA. I am starting to get comfortable mixing and laying up glass.
I am still unsure what to use over the final West epoxy/microballoon layer to get rid of the final sanding scratches. The contour is good. Some kind of fine filler or heavy primer?
What works? (I am not sure of what primer/paint I will eventually use).
The second question is what to do with the ill-fitting fiberglass tips on one of the elevators.
When matched up horizontally, the elevator side sticks out laterally a good 3/16".
Do I cut down the elevator tip or build up the HS portion?
If I pull it out there is no flange left for the rivets to go through.
Anyone figured out the best way to fix this?
Dave A.
6A
Dave A.
6A
