WingedFrog
As the actuation brackets are riveted with solid rivets and as the pivot brackets are made of the same material, same thickness, I was going to rivet the pivot brackets with the same solid rivets as the actuation brackets. Having a look at Marty's log, I saw that his pivot brackets were riveted with pulled rivets. Although it's not very clear on the instruction page, I thought that the pulled rivets were used only for the ribs, not for thicker material like the brackets. If that is the case, there should be a call for longer pulled rivets than for the ribs. ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
A search or other web sites did not provide any clarification.
Any advice?
Any advice?
