A bit off-topic, but I am looking to upgrade my compressor. Going with a 230V, single-phase, oil-lubricated unit. I've read a lot of positive recommendations for two-stage units here. Problem is, from my research, the "high-end" of the single-stage units are rated a lot better per dollar than the "low-end" two-stage units. I know that "HP" ratings are to be regarded with suspicion, but how reliable are the CFM ratings?
Example - two Ingersoll-Rand units with the same warranty:
#1, single-stage, continuous-duty motor, 60 gal. tank, 18.X CFM@90PSI, 15.X CFM@135PSI, $900.
#2, two-stage, continuous-duty motor, 60 gal. tank, 14.X CFM@90PSI, 14.X PSI@175PSI, $1200.
I don't have any need for air over 135 PSI. So I guess my question is, is there some compelling attribute about the two-stage unit that makes it worth 33% more money when the performance is worse?
