Now that I have about 23 hours on my standard 8.5:1 ECI 0-360 the CHT's are settling down, is there any document or rule of thumb that I can use to check that the fuel flows are within reason (i.e I am not running on the rich side to cool the cylinders).
For example today's numbers were 65% power according to the Dynon at 7500 FT, OAT 48 with a fuel flow of around 9 GPH, CHT on #3 was 395, EGT around 1370.
Do these seem like reasonable numbers, as you can tell I do not know a lot about aircraft engines, on my Pacer it just has a tach![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
