I have an opportunity to pick up an 0-360 A1AD for my -7, this engine has a single, two-in-one mag. Has anyone out there fitted one to a -7? My concern is whether the larger mag will clear the engine mount.
The dual bendix mag on my A1F6D fit in the mount on my 7 fine, after installing the engine I ended up using electronic ignition. The biggest difference I found was the oil cooler lines in the accessory case were straight thread with O-rings and not NPT. Good Luck!
