LOW OIL PRESSURE; THE CAUSE..
Well Gents after looking at every possible angle to find the cause of my sudden lack of oil pressure on my 0-320 E2D RV-4 we finally found it today..
And trust me it wasn't the outcome I was looking for...
To summarize, we installed and removed the accessory case a few times to look at the pump, the oil gallery going from the pan to the pump, built an homemade pre-oiler to make sure the pump/engine was properly oiled and primed before doing test to no avail...: No oil pressure.
Today I borrowed a friend's Grumman and took the accessory case to the overhaul shop so that they could test the oil pump and it turned out to be ok.
While talking to the shop's owner he told us about possible causes eventough he never heard of an engine going from having oil pressure to none while seating in the hangar with a serviceable oil pump.
So off we went back to our strip and with the accessory case still off, my friend carefully pressurized the engine again and there it was....
Both Crankcase half are cracked on either side of the cam and there is another crack going from about an inch and a half below the cam to about level with the crack....that engine was litterally within minutes to stop working....
Eventough I'm pissed at having to rebuild this engine again after 250 hrs ( had to rebuild it at 300 hrs 6 years ago ) I thanked my lucky star it didn't quit on me 3 weeks ago when IFR with 500 feet ceiling..
So tomorrow I'm gonna take the engine ( minus cylinders/oil pan & rear case ) to the overhaul shop and get it fix...I will find out soon enough how much $$$ it's gonna cost...
So listen to your engine,it's talking to you..mine sure did...
Bruno
[email protected]
ps: I've got pictures of the cracks but can't post them here, if you wanna see them, send me an e-mail and I'll send them your way.
