Another Engine Delay
200 defective crankshafts are a lot for a small production line like Lycoming. I wonder how the QC was maintained at the subcontractor.
I don't know about the QC, but that crank manufacturer sure did get a solid glazing in that big jingo promo video they published several weeks back. Nothing to do but laugh and ponder what they knew about this when they put that out, patting each other on the back.
200 defective crankshafts are a lot for a small production line like Lycoming. I wonder how the QC was maintained at the subcontractor. If these are destined for certified engines, I wonder if the FAA will get involved.
If it makes anyone feel better GM has a recall on 597,000 6.2 Liter L87 crankshafts currently. Estimate $1 billion liability. Number of affected engines likely to increase. Maybe 200 before the QC process caught it isn't too bad....
According to the video in the first post of this thread;
-The cylinder heads come from an Eck industries foundry
-The crank cases are cast and machined by Kurt Mfg
-The cams & Crank come from Aviation Mfg Company (a division of Callies Performance)
Yes, and Callies Performance is a GM engine component supplier. Crankshafts. I wonder if this has anything to do with the 6.2L L87 engine recall. Callies may be involved in the several hundred thousand engine recall! That's a lot of crankshafts!
Hmmm, I didn't know they supply GM as well. It's certainly possible they got a rail car of raw stock that had bad metallurgy and caused all of this. If that's the case it's possible there are Lycoming's already delivered with suspect cranks.
A very unfortunate situation. Callies has always had a good reputation. I suspect this wasn't caused by direct errors on their part. Likely an issue that hadn't been recognized as possible, so QC was not set up to catch.
If my engine shop bought a new angle valve Lycoming crank, non-counterweighted, sometime around Aug/Sept, how would I find out if there's a defect?
Hope Lycoming has good parts source records.
Apparently GM crank issue is a manufacturing defect where crank was not polished correctly. Perhaps DanH can explain RA and RZ and the importance of the ratio of the two. I don't know what Lycoming's QC process is or who/where in the manufacturer supply chain the crank gets polished or who is responsible. The good news is the defect can be remediated if caught before crank is put in service. I suspect the delay at Lycoming will become longer as the supply issues are investigated. I fear a repeat of the Superior crank debacle though, which is a nice way of saying it really is time for serious consideration of other engine variants to be developed with Van's engineering support.
RA is the fine-ness, if you will of the machined or ground surface….RZ is the peak to valley depth…
When you machine or grind, you leave cutting marks…the lower the RA..the finer the polish.
Apparently these cranks were not adequately polished.
In other words, what the heck is taking Deltahawk soo long??? Those engines would cover the majority of Vans aircraft ordered today (the -14, -15 and -10). Us single digit RV flyers are a bit more reliant on the legacy GA engine builders.
I'm sure @cjs will weigh in, but DH is working on a FF package right now for the RV-14. When I toured their facility, they were getting ready to modify a C-172 and Piper had just dropped off a brand new Seminole to be converted to DH engines. There was a DH-owned Cirrus (SR20 I think) with a DH engine there. Craig and Synergy will shortly be working on a DH 235hp powered RV-10 and then hopefully a couple of us will be doing a DH 235 powered RV-15. DH is also working on their 6 cylinder 350hp engine. They are a small company, but appear to be well funded by an entrepreneur with a passion for aviation. They want to pursue FAA certification for these other engines (the 180 is already certified) which takes a lot of time and even more money.
Not a lot I can add to that - you’ve pretty much described accurately the plan we’re operating on currently.
We are planning to have the ‘production’ DeltaHawk RV14 at AirVenture 2026. This would have the firewall forward package DH plans to offer to RV14 builders. The plan is the FF package comes complete - the engine, and all the bits, attached to the engine mount. Pre-tested and pre-run. Very plug-n-play.
Lots going on now to achieve this. Once the plane gets back to us (at SynergyAir in Eugene,OR) in April for final assembly, I’ll post more frequent updates on the progress.
All good points. I tend to look at the core acquisition task as a need to buy before it gets into the parts distribution chain, much as I bought trucks from owners and leasing companies before they went to auctions and dealers. Here at 08A, I recently watched four airplanes go to a salvage house (meaning five engines) at $5K apiece.
Guy who made living on price arbitrage with vehicles is better at finding deals than average guy. News at 11.
Seriously though - finding deals, verifying the suitability of parts, figuring the probability that parts are good or not, and not getting burned (or just unlucky) is itself a skill. If I tried to do that with an airplane engine, I would never trust it.
Just to update my earlier comment on my Titan order.
I got a call on 6/1/26 to confirm some final details as the engine is going into production this or next week.
I Originally placed my deposit on 3/27/25 and modified the quote/order on 5/20/25. I don't know if the change order altered my place in line but with the original order this puts Continental at a 12-13 month lead time which is what was told to be last year when i placed my order.
I'm not too far out with finishing up my wiring then I'm moving on to the canopy so my timing has worked out fairly well. Hopefully the engine will only sit in the crate for a few months before hanging.
I finally received my engine today. The KitStatus page still shows May 22, 2026. There is no updated information from Vans. No delivery information from Vans. But, it is in my possession now 😊after 3 years and 6 months.
Congrats! Was it a Thunderbolt?
So you got a call from LYC we have your engine ready to ship without any heads up from Vans?
Better lock your hanger door. It would be shame if that engine disappeared one night.
Greg Beckner
I actually had more info from Zlycoming than from Vans
Kit status says my Thunderbolt is to ship today. I emailed Vans and they can't get a status update from Lycoming because their contact is out until Monday. But he had some other bad news for me: my Barry mounts, which were also projected to be available now, will not be available until August 5. It's only a month but I'm dead-in-the-water until the engine and mounts arrive.
Are there any substitutes for the Barry mounts?
Lord mounts from ACS or the clone they sell if that answers your question.
My neighbor who also is building an RV14 ordered the same mounts from Aircraft Spruce for the same delayed by VA
In case anyone is in the same boat, the Barry part # is 94011-20 and the Lord part # is J9613-40. Aircraft Spruce has the Lord mounts. Also, keep in mind Vans will only fund the amount you paid when you ordered the FWF kit. Since I ordered the kit 2 ½ years ago, that price is about half of what it is now.
I was told the other day that they get a daily update from Lycoming...so my question to them would be what was the shipping status on yesterday's update if I can't get today's update? This is really strange.
My date has said 6/19 in the portal since the updates with the crankshaft delays were published. Since that day has clearly come and gone I asked for an update and was given 7/28 as a date now... SMH
My Thunderbolt ship date has also been delayed again. As of Friday it was 7/2. Now it is 7/23. Order date: 4/27/23.
You might try Pilot John, I got some from them back in March and they were cheaper than Spruce.
Well, it could be worse. My Thunderbolt ship date is currently 8/17/26. I ordered it the same day you ordered yours :-)
Are the FWF kits not shipping when ordered these days or are there lots of backordered components? I was going to order the kit just to get ahead of the game, but maybe it makes more sense to get the bits and pieces elsewhere, less (of course) the Van's-specific items like baffles, control cable brackets, etc.
I ordered my FWF kit last year in September. I think I finally got the final parts of it this spring. Yes, they are back ordered on various pieces at different times. Engine mounts are an issue right now for example. Best to get it ordered asap if you have the money. It isn't headed down in price
FWIW, this is what I deleted from my FWF last year along with the credit I received:
https://vansairforce.net/threads/vans-part-prices-caveat-emptor.237914/post-1873917
Great info, though Van's says that they're no longer permitting additions/deletions to/from their various kits, though perhaps they just mean the basic airframe kits. I sure hope they'll permit it, as the most cursory of initial searches has turned up stock (and better prices!) on several items from other vendors.
If they don't allow deletions from the full kit, then just put each individual item in your cart that you want and order it that way. I printed the whole kit list and figured out what I wouldn't need/already have and went through the store adding each thing individually. I haven't placed the order yet as I'm still about 6-8mos from needing it.
Great idea; I'll do exactly that.
You CAN delete items from the kit. If you buy them individually from the web store, you will pay a lot more because they put a huge markup on items bought that way.
I think I'll delete everything that I can source elsewhere. All I really need from Van's are the RV-specific parts they make themselves. Everything else is aero-generic and both cheaper and in stock at other vendors.
I would look at it two ways: 1-as deletions from the FWF kit, assuming you only get 50% of the retail price as a deduction, and 2- just buying the items you want on the web store at full retail. This might surprise you as to what the totals come out to. In case one, get Vans to give you a quote so you see what the deductions add up to.
How was camping at Lycoming's booth Mark? Did you get any further updates on your 390?
Actually, I was pleasantly surprised at the Vans session on Monday. Chris Gayman got up and addressed the issues head on. The issue is not the PMags (much to the dismay of those suffering from PMag Derangement Syndrome), but the availability of the crankshaft bearings which they get from an Israeli company. That company has slowed shipping largely because of the war. Sean from Vans (reports to Mikael Via I think) also said that they were only aware of the bearing issue and said he wasn't aware of a PMag issue (much to the dismay of those suffering from PMag Derangement Syndrome)...and he said that they were getting a shipment of the bearings next week or so. I guess we'll see. All in all, I think that the Vans presentation was much better than last year and they addressed the issues squarely.
But, WHY DOES IT TAKE HAVING TO GO TO AIRVENTURE TO GET THIS KIND OF INFO??????????????????????????????
"What do I know?
Who else needs to know it?
Have I told them yet?"
An "auld sawe" when I first heard it...
