7 777pilot I'm New Here Patron Jun 13, 2026 #1 Hello, Apologies if this has been asked before. What is your favorite place to mount the Vans Egress hammer? If you have a photo that is even better. Thanks, Seth
Mike S Senior Curmudgeon Jun 13, 2026 #2 Think about what would cause you to need it. Would you be upside down?? Methinks most likely. Try to put it somewhere easy to access in a crash situation.
Jetmart Well Known Member Friend Patron Jun 14, 2026 #3 I put mine on the flap cover between the two seats. Mounted just high enough to get to the bottom floor screws of the flap cover. Zero interference for the passengers and I figured it was easy to get to by either the pilot or passenger. Last edited: Jun 18, 2026
