I recently installed the Engine Bridge Data Monitor, connected to a pair of eMag Air (now Hartzell) pMag v114's, and have less than 10 hours on the setup. Word of caution: do not send a "save command" while changing timing settings airborne. This is in small font in the engine bridge manual:
"Note when changing settings in PMag, itis recommended to do so on the ground(with or without the engine running). A slight engine “miss” may be noticeable while the PMag is saving the data as during the few milliseconds the PMags need to save the new settings to its internal memory; the coils are not firing."
I have Pmag firmware v41 installed, updated ignition timing airborne, hit send, then clicked "save". One pMag did not reboot. Lost a mag for ~1 minute while I troubleshot the issue. Sending another command (pMag Setting) solved the issue. I was VFR at the time and well within glide distance of a runway, so manageable, but gets your attention.
