DakotaHawk
I just had the prop shop inspect my prop, clean up the blades, and lube up the internals on my CS Hartzell. The prop looks great!
Today, I began fitting the spinner onto the prop, and found that when the forward spinner bulkhead is attached with the 4 bolts in the hub, the bulkhead nutplates are no longer aligned with the spinner.
I'm assuming that the hub cover was rotated while at the prop shop, but now I need to get everything lined up again. There's a large nut (maybe 9/16"?) on the front of the prop, but I'm hesitant to try to loosen it or attempt to rotate the prop hub cover if it's going to screw up something internal.
Any suggestions are welcome!
