I am helping a friend with his new RV14 that has a really high oil temp and I am wondering what sort of things could play a role. Here is the circumstance, the engine will get to 220F range in about 10-15 minute run on the ground, they saw a 235F at the runup and thought it would cool down if flown, one turn in the pattern the oil got to 245F when they decided to land. Oil pressure has been good and the scat tubing to the cooler has been checked as well as anything sucked into the oil cooler.
Besides, the usual suspect of oil temp sensor, Vernatherm, ignition timing and possibly a clogged oil cooler, what other things should be checked? Is there any relatively easy way of checking the oil cooler for restriction?
I have not seen the plane yet but have agreed to go and help him troubleshoot as he is not very knowledgeable in these regards.
Thanks in advance for any suggestions
