DeltaRomeo
doug reeves: unfluencer
Staff member
67 days. Isn't that embarrassing? "Hey Siri, how many days has it been since March 1st?" Ugh.
Flu, wife’s broken ankle, condition inspection, etc…..usual time excuses. FINALLY the universe tumblers allowed a flight Tuesday morning. New tailwheel, new grease, new main wheel bearings/grease.
Post heavy MX, I’m in the Nomex gear and staying close until I’m happy with the temps and pressures. Skills a little rusty - gives me a goal. After a bit, over to XBP for fuel. An RV pulled up to the hangar across the taxiway from me after I returned and I offered them some shade while they were visiting their friends. They’re everywhere <g>.
Back in the RV saddle. Mental gyros re-aligned. Hope the same with you.
v/r,dr
VAF POSTS & RV NEWS THAT CAUGHT MY EYE.....dr:
From Last Weekend’s ‘What did you do’ thread.
Flew 1532NM across Australia.
https://vansairforce.net/threads/wh...this-weekend-may-4-5-2024.226597/post-1766417
Formation Pilots Needed For Memorial Day Flying - SE Michigan
...Terry Lutz asking.
Understanding Battery limitations - Help please
https://vansairforce.net/threads/understanding-battery-limitations-help-please.226681/
Fuel leak at carb inlet …update
I cleaned the stains off the carb body today, slightly tightened the inlet fitting, and ran the boost pump for several minutes. No sign of any leaks anywhere. Satisfied, I buttoned up and went for a 30 minute flight. Checked again when I got back, and found more blue stain. This time, it almost looks like the leak may be coming from around the head of one of the bolts into the bowl. Doesn't look to be coming from around the gasket. Is a leak here possible? I assume a fix will just mean dropping the carb and tightening that bolt up a tad. Not the end of the world, but wanted to make sure I'm not missing another possible source. Thanks
OFF TOPIC:
PS: Older issues of the ‘VAF News’ can be found at:
