DeltaRomeo
doug reeves: unfluencer
Staff member
To the wonderful RV fans helping keep this 1-person business afloat with a badge under their username, thank you from the bottom of my heart.
I hope everyone had a great weekend.
v/r,dr
If you create a good fit for your fairing you won’t need so many screws. I just use regular round head screws on that fairing and it looks fine.
Probably lose about .007 MPH though.
Fluting is necessary both the straighten the rib but also to create proper spacing between holes. If you are just flattening, you may want to measure hole spacing on your skin and compare it to what you have on the rib. You may be surprised.
A related issue...my nose skins have small bumps associated with the corner of the top front tab on the noseless ribs. If I had it to do over again, I would trim the edge of those front tabs back a bit.
I mounted mine at map box location at an angle that makes it easy to see from the pilot seat. The left side almost touches the panel, and the right side is about 4" away with a slight up tilt. The idea was to reduce the off-axis viewing angle. Despite the reflection in the photo, glare is not really an issue in-flight. I prefer the Skyview display for ADS-B traffic SA, but the iPad is handy for a quick speed check on a target.
OFF TOPIC:
https://vansairforce.net/threads/the-vaf-list-a-list-of-rv-related-lists.223964/
Past ‘VAF News’ issues:
