DeltaRomeo
doug reeves: unfluencer
Staff member
As 2024 reaches its final few ticks, I wanted to thank you for helping to make this site what it is over these past 12 months (11 months since the cutover to the new software). The knowledge base contained here, one that always expands, never ceases to amaze me in its technical focus, motivation, fellowship and comedic relief. It’s a handful to run to be sure*, but I really do believe the RV universe is a better place with VAF in the mix. And while it hasn’t been the most pleasant of years with the mothership ch11, I’m grateful to have a wonderfully capable GA airplane coupled with a large contact list of kind, helpful RV friends.
Thank you for sharing your year with me here.
I hope you and yours have a happy, safe, RV-filled and Blessed 2025.
v/r,dr
*mild understatement
dr
Welcoming kenandsteph14
…new to the community. Checking in.
339A MX PIREP
RE DIY Repair of Squeezer
…rongawer
I recommend you doing the service yourself. They're pretty simple internally and generally just need the o-rings replaced. You might just pull it apart (take photos for reference as you disassemble it) and measure for replacement o-rings. My old Chicago pneumatics (made back when it was actually made in the US...) uses a harder durometer BUNA o-ring, but you can use Viton as well. Any simple hydraulic fluid will work; I use MIL-5606H, but jack fluid from Harbor Freight will do the job as well. If you have a newer unit, it might have teflon rings as well; both are available at various suppliers. Reassemble with silicone grease and you should find it's working much like new.
PaulvS
HFS
AirplaneDetective
dr
OFF TOPIC:
