erikpmort
Go to Set Menu > General Setup, and you should be able to select between kts and mph under the speed and distance units.
http://www.grtavionics.com/Mini-X A2.pdf Page 25.
I have about 6.5 hours on my Mini-X and HX now (converted from an old analog panel like you are doing). It is a pretty big change to go from the analog airspeed indicator to the digital speed tape. I am getting there, and I am still "Chasing the numbers" a bit when on final approach, but I think this is having a positive effect of keeping the airspeed more controlled versus the analog gauge where it is harder to tell a couple of knots difference. It is getting easier with practice, but it was definitely a surprise on first flight.
-Dj
Forgive my lack of understanding but what are the consequences of not sealing the backing plate and what would happen if I just left the hoses on the pump and left it on ? Not planning on doing it just wanting to learn
