Hello Jim,
Yes, you should be able to configure the GPSMAP 696 serial port for "Aviation In/NMEA & VHF Out" and connect the single 696 output to the inputs on both the GTR 200 and G5.
Steve
Hi Steve would you have a diagram for the multiple connections of the RS-232 as I want to connect all of these together.
Aera 660
Trutrak autopilot
Garmin sl40
and a G5
Aera 660
Trutrak autopilot
Garmin sl40
and a G5
Hello TC,
Page 7-5 of the Rev. 4 G5 installation manual shows how to wire the RS-232 #1 output of the Aera 660 bare wire cable to a G5 to provide lateral and vertical navigation guidance to the G5.
If you configure the Aera 660 RS-232 port #1 to "Aviation In/NMEA & VHF Out", and connect the blue wire to the RS-232 input on G5, SL 40 and TT autopilot, you should be able to drive all 3 devices.
The "VHF Out" part of this transmission will allow you to select a frequency on the Aera 660 airport frequency page and send it to SL 40, and the "NMEA" part of this transmission provides navigation guidance to the G5 and autopilot for a direct-to or flight plan.
Since the Aera 660 has 2 RS-232 ports, this will leave the 2nd port available to connect an ADS-B traffic/weather receiver like the GDL 39/39R/50/50R/52/52R.
ACtC-3fO6_22dnyE4z2a8JjpBfUcqKoQfwOcfhhdQpe_ytEKKOKrVrmpTHllgPMnTmPAE62ffXFMFxQcan7ekenp5zrKL24n_svOlYTzk6idst8EgKoRh89x3LWIhrqsDQz5gB9h6uK-K8Z30hoLStZLeT6Q=w720
Not exactly your equipment group, but it shows both RS-232 ports in use.
Let us know if you have additional questions. It is best to email us directly at the email shown below for specific wiring questions.
Hello TC,
HbqZbKzeRvLBvXQSU42BuGG_1vvHO4QbBX5rKTqWLHfP8EK0m0-ARVvWunWDqJtNSV3vYVY8lBnyua1yW0Q4KgIZ0jifndFiohf_dcRTbDueRSL4AS8IfPSuzVwN-cl00gS8-Ir_1TYxGBLQTo4Kx2C-M0A1HwL22RW6AIzLFprHe5-6fNMv5s8GgPthG7vrPmwpFzSO-vYkOFcHWXMb0aMJgMqpvobGSuhFRZOA9GTCJCSJiqWEjUD5nvn9NuXfsR2zY5yyXLV9HNduIq63AVyBn7xvT-QKpXdEOLXr-NW39Pagr-1Cvg9R20l3Dgx9QjtgA2ooypxYVKlM6DsilHI3teVHlSy9fs-xsTDrCEcx0OZcOLMhJPkWHxHXdroc2F_E5kL3L1ELwMMyGL-hCVPE6VRmKJWoQCdbHUS0DoW0Q9gLK_VfXTmVp4_mrofVxURlgeFcR7iPKfHfzN9xEypaGs4DwVbIFDDLD8RoWGKNOOmFShazGKbeRablSXh9RwzX3U--9ALWi5IK4JxDna1s09m7dkeXkfjaaxxUmY6kNrlxRCQEpAV-6NEOrNDD2XHQUoX-ykdg3giuP5dJ2r-smtNvM0KJop8fGfrnWg9lS_6kngNHdNgiXSA7dyfIXhMYUBG-I4rgBBpNpDTr8Jvteu6IYn4=w720
qcrh12v8FldAxhZ5EWWxKe1cn6kRpeb9J1nkFMmqCbgvJtqnXIGeb5A8BiTsBLk-s9hjCj6s7LxMH0Pp8zuGluoWe2c2ylc_Ukpe9xUxvlvhnlq3p_JnRTxOptfwffbRZKYGMi4u4L8WuzI5AfvwJfRTX5QiFDZC1i1f-g0-nCbxfw6KRmoP9pSRbS05vXGyQLXbMnk8P0B5pCBEY3syzUFJ6fLCe7DZUgqvdOMsSIXPTllEltner3jKFLvkMuCym9yOLASgN1Nc-YjaBnXzci00iHPk9o-zB8q2DySqdxOPjuIUll5-GzRzXt7TjrMzomE-SY1YsNQxiRLFWkA1s3__5g8tyyeesNgGYsafB3ouQFjWFry3a0O3dy_OhK7N9ivjvFSReA5sT9nVHBsxs_4ygnt9VrLqzQjROGYbAgC2XHIumS1UdktX6geaW5CUPNhm34-pVpNIjXXlJ5SntCqutWDVmdEXY8_sib4eYrr7O2YAqtWNvWRg2ybjZjcAucp5f_RokYnqOe8fY-C5g1Op3cIx9eSz66zoyooh2mEXnLYvQZ8tJ5LucJ3yMEB1JMT-nMkGlC2PGnrAwsxAtZ13_QqqnzQEHYbZPmHDu-zm27uGIWTmgaQUuM9f3mZTirI7WcYu6G3pPeBk2t4_6-TZ-HdoOU0=w720
could you please repost pics .... thanks
