Ben Ellis
Sponsor
This question is more for G3XPERT but I'm putting it out there for everyone. I'm going to be upgrading my GDU460 to a GDU116Bx as soon as I receive the unit from Stein. So I have started to plan the changes to my electrical system. A few issues that have come up:
The installation manual says that if you used the GAD 27 keep alive function with G3X that you should disconnect this and connect the Axis flight display directly to the electrical system. Without the GAD 27 or a backup battery, does the Axis display have some sort of brownout protection that will keep the Axis display powered when cranking the engine? If not, does Garmin recommend a backup battery?
Also regarding the increase from 2 power inputs to 4 power inputs for the J1012 connector -- which note 6 to Figure B-1.1 says is for the PFD/MFD/GPS functions -- I have several questions:
1) Is the J1012 connector also for the USB-C charging (since I note the power inputs on the J1015 connector are only needed for the GDU116C/NC units per note 8 to Figure B-1.1)?
2) The paragraph above says that if you have a backup battery, you can put it into one of the J1012 power inputs. Does that mean that any one of these inputs can power all PFD/MFD/GPS functions, or is there reduced functionality if only running on one input through the backup battery in the event of electrical system failure? Assuming the answer is all these functions can be powered on one input, then what's the purpose of 4 vs 2 power inputs since 1 extra input would solve for redundancy?
3) Is the GPS functionality referred to in note 6 the built in IFR GPS that comes with the C/NC units or the built in VFR GPS that comes with the Bx unit? If IFR GPS, then are all four inputs still needed for the B units?
4) If all four are truly needed, do they all equally draw the same amount of current? The main reason I ask is because my existing GDU460 wiring is two 22AWG runs, one on a 5A breaker and one on a 5A fuse (fed from the e-bus to which the GAD27 keep alive power flows). Ideally I could keep those two runs and just add two more that are 20AWG.
5) What does Garmin recommend for the breaker size that all four inputs are tied to?
6) Usually when I see splicing like that it is a bigger wire run that is stepped down in gauge to fit the dsub pins. Does Garmin recommend a larger gauge between the breakers and the pin splice?
J1012 Connector:
I note the increase in max draw over the G3X's 2A at 14V:
Installation manual 3.4.2 GDU Power Requirements says "The main 50-pin connector (J1012) has four main power inputs. This connector is present on all display variants. All four power and ground connections should be connected to the aircraft electrical system. It is acceptable to use one of these power inputs for a connection to a backup battery, if equipped."
If one pin connected to a backup battery is sufficient to keep the display working then why are 4 pins needed for normal operation? Wouldn't one expect half the pins to be allocated to primary power and half allocated to backup power?
When Garmin LRU have redundant power inputs then they are often described as "diode ORed". I found no such description of the AXIS DU power input pins.
I would like to see at least a block diagram level representation of the internal power distribution.
GAD27 protects against voltage sag while starting. This was important for GDU 4XX, AXIS is capable of handling the temporary interruption however.
A backup battery serves as backup power for the system to operate on, in the absence of the primary electrical system, and is also used to protect against voltage sag during engine start in many G3X Touch systems. We expect many AXIS system to incorporate backup batteries to run the system in the case of an electrical system failure. The use of backup batteries is discussed in the installation manual.
You are correct.
Full 27W USB-C charging is not available on only 1 power input pin, which changes the power consumption of the device. The system has different power requirements from G3X Touch in general and we strongly suggest providing power to all 4 inputs. As mentioned in the manual, if a backup battery is incorporated in the system, use one (and only one) of those inputs for that connection.
Yes, both. Yes, use all 4 inputs to balance the power load on either variant.
Yes
If wired as shown, 7.5A @14V.
@g3xpert :
Does the 8" portrait display capable of split screen and more specifically, can it display/control the Autopilot much in the same that the G3X has done? Will there be any manual available for the 8"
Here's what I'm going with:
The 4 power inputs on J1012 are diode ORed. We will clarify this in the installation manual.
@g3xpert :
Yes to all questions. The installation documentation will be available closer to the Q1 2027 release date for the 8 inch displays. If there is something you are hoping to work out specifically for your installation as it relates to the 8 inch displays, please email us at [email protected] and we will work to get you the information you need.
You are correct.
Yes
So, in addition to power inputs ALL 4 power grounds MUST BE connected ?
Tom
I'm curious about this too and alternatively, if using all four ground pins, does each wire need to go back to the common ground point or can the four grounds be spliced close to the device with one wire going back to the ground point?
I'm very curious why the device calls for four 20awg power inputs fed from a common breaker and four 20awg grounds to power a max of 4.4A. Is this to lower voltage drop? Or is this one of those things the FAA requires for certification just because? Maybe some of the electrical engineers here can shine some light on this.
this iis to support the USB charging capability on the usb-c port in the bezzel.
But since the total draw of the unit with the USB-C charging maxes out at 4.4A and all inputs tie to one breaker, why are four power inputs needed to support charging and the unit in general? I’m trying to figure out the technical/engineering reasons.
A bigger puzzle is that Garmin suggest a single power pin is used for backup power. In my aircraft I run all G3X Touch LRU for extended periods on IBBS (database loading, configuration review and edit, etc.). I asked g3xpert why one pin was sufficient to power AXIS on backup power but 3 would be required for normal power (MAIN bus in my aircraft). That question was not answered.
M39029/64-369 pins are rated at 7.5 A each so the use of 4 pins does not seem to be driven by pin rating.
It was somewhere else - the USB is the big draw and disabled when running on one wire
It maybe prohibited but how would it be disabled?
We have been told the 4 input pins are diode ORed so they feed a common point in the AXIS DU. Yes, it would be possible to have current sensing on each input before the ORing diodes but I have seen no indication that is done.
The question of why still remains. If 4.4A (which is enough to support full charging and all functions) can be technically be pulled on one pin then why are four inputs needed/recommended, especially when all four pins are tied to the same power source. The only benefit I see is it reduces the load on each of the four wires, perhaps reducing voltage drop (?), but any one wire can easily handle 4.4A so the benefit isn’t clear to me.
I am still installing stand-alone USB-C jacks on the instrument panel itself. It's simply not worth buggering up a USB connector on a $20K device.
My thought too and if I fitted an AXIS DU I wouldn't consider powering anything from that USB-C port.
With my current G3X GDU I can pull the SD card and take it home to archive flight logs and config settings. No need to have the GDU powered. Retrieving flight logs from AXIS seems to require not only powering up but navigating menus. I don't see how that is an improvement but I suppose it caters to iPad users.
I think this is now done wirelessly via iPad app automatically, although I'm not 100% sure. It's a question for the Garmin folks next week at OSH, unless they can answer here.
That may be an option but, since I don't own an iPad, I have not checked.
Downloading flight logs to a USB-C memory stick (the equivalent of the earlier SD card) requires the DU to be powered and navigating the menus. In the GDU 460/465 the logs were recorded on the SD card anytime one was present.
For my intended usage the change from SD to USB-C is a step backwards in terms of convenience and vulnerability to damage.
Plenty of low profile options for usb drives you could leave inserted:
It will also transfer wirelessly to Garmin Pilot using your iPhone or Android, you don't need an iPad.
Maybe not as simple as SD cards, but they seam to be going away in general and prone to failure.
Except that SD cards do not snap off in an impact and the data is already written if the screen is destroyed
ie better chance of recovering data post crash.
I’ve sent in more than one unit for card reader problems, usually due to fat fingers as they are a bit fragile.
Maybe C is a little less convenient, but it’s more robust IMO.
Would greatly prefer a non-Garmin-Pilot way to do it, as I don't use that.
I wouldn’t hold my breath on them adding an SD card back into the hardware profile. Just pointing out there are alternatives. Personally I’d much prefer the WiFi option. Nothing to snap off, nothing to break, nothing to lose.
Ordered my complete panel yesterday so we’ll see how it goes.
I've had my issues with SD card as well....... And G charges full price to repair a broken 10¢ spring on the SD receptacle.
Interesting to hear of problems with SD cards. I have been using them in various applications for about 20 years and never had a problem with a card or card slot.
I suppose the USB-C would be more robust as it uses no latching/ejection mechanism. If a low profile USB-C memory could be used, and Garmin would write logs to that memory in real time, then I could see that USB-C would be better that SD.
edit to correct CF to SD. I used CF before SD.
There been problems with SD cards and BT causing in flight shutdowns in G3XT in the past.
There’s always unintended consequences and risk involved with having any external connectivity.
In my industry there’s no way anyone gets anywhere near critical production machines with any physical or wireless connection. And nobody’s life is on the line.
But this is a micro-processor device.
It will always need some mechanism to update operating system software and mapping databases.
Of course. Just making the point that it’s not risk free. As they have found with the last generation.
I imagine these changes are designed to improve the situation.
J1012 Connector:
These Dsub pins are conservatively rated at 1A per pin, in some circles. Given the ~4 -5 amp max draw, I can understand the use of 4 pins for max draw. I kind of doubt that current sensing is used on each pin though. I think your dual splice, 20 AWG wire selection with another sum at the breaker is a reasonable approach. I will be doing something quite similar but with a single VPX output driving the display.
I don’t think so given my panel builder used one power source for my current G3X. Can you reference where you found 1 amp? This from DigiKey. This is a high-density pin, M39029/64-369 pins are rated at 7.5 A. (D-Sub Contact Male Pin Gold 20-24 AWG Crimp Machined)
I don’t think so given my panel builder used one power source for my current G3X. Can you reference where you found 1 amp ? This from DigiKey.
No, not very credibly. 1 amp was used on some hi-rel space programs I worked on. And it is definitely a low number. The rating may also be based on components or board traces behind the connector. But I can see the possible mindset of the designer. Things get a little more reasonable when you use one of the pins for a backup battery, per the Garmin instructions. Maybe the Garmin folks can comment.
dsubs contacts are generally rated for 5-7 amps, based upon the type. While many designers will cut that in half to be conservative, 1A is way below the general standards used every day. no surprise that space shuttle designers are VERY conservative, but that doesn't mean it makes sense in other areas.
Is there still a 32 GB limit with AXIS ?
I asked the Garmin rep today and he said no, there is no 32GB limit for Axis. He said they tested a variety of sizes including >1TB and the only problem with the larger capacity USB drives is they are slower.
He also said only the Garmin CO detector works with Axis. Not sure about that either...
The GCO14 carbon monoxide detector is on the supported devices list.
Hopefully it will be supported on the G3X Touch soon.
The Aithre Shield EX has been supported for over a year via GEA24 so you would think it would work the same way with AXIS.
