Frog Hobson
Member
Any updates?
That said, Here’s a few of the things a modern DeltaHawk engine provides:
Mechanical FI (fuel injection) and no EI (electronic Ignition). It’s a robust and simple system. And, yes - no mixture knob. Maybe that’s not a big deal to some, but I find it liberating (I fly both a lycoming RV14 and the DeltaHawk14). Would you be happy continually fiddling w the mixture knob in your modern car engine?
Water cooling vs air cooling: Allows for more consistent operating temps and closer tolerances in the build. My IO-390 burns about 1qt of oil for every 5 hours of operation - not unusual according to Lycoming. The DeltaHawk does much better. No shock cooling worries. No worries about managing temps on climb-out on hotter days.
No spark plugs or mags. Having just dealt with a misfiring plug on my Lycoming, and previously having to overhaul the PMags (after only 500 hours) I won’t miss this or the related costs.
Native Forced Air - the DeltaHawk is supercharged and turbo-charged as part of its basic design. The ability to produce full power regardless of the density altitude (to 17k’) is a huge benefit. I primarily fly in the mountains - where the benefit is obvious. But, even flat-landers can appreciate this when taking off on a hot day at gross weight.
How ‘bout that fuel efficiency. I’ve consistently seen 35-40% better fuel efficiency in the DH vs my IO-390. Even if one only flies 100 hours a year here’s some math:
Lycoming: 100 hrs x 10 gph = 1000 gals. $6/gal. $6000 on fuel.
DeltaHawk: 100 hrs x 7 gph = 700 gals. $5.50/gal. $3850 on fuel.
$2150/ year savings. Not to mention you’re probably burning less oil and have less maintenance (plugs, cost of annual, etc).
Note: I only used a 30% fuel savings in the example. Also, I generally find diesel $.75 to $1.00 cheaper than 100LL. Although the past couple months both have been horribly pricey.
All this said, will the DeltaHawk be a true alternative to the Lycoming? I don’t know - but, based on my experience w the engine and the company so far, I believe it will be. Will all this happen overnight. Clearly not. But, a lot of progress has been made to date and I’m excited for AirVenture to show this.
Finally, we’re working w SynergyAir on a true apples-to-apples comparison on the cost of purchasing and installing the DeltaHawk engine on the 14. I think most will be surprised at how price competitive the DH will be. DeltaHawk is planning to provide a complete, assembled, tested, and mounted engine with all the associated components (forced induction, radiators, starter, alternator, cowling, etc, etc.). I suspect when one actually compares the price of the lycoming with all the bits and pieces to achieve the same end result, the DeltaHawk may come out equal or less costly.
CJS
Rv10inOzHi Craig,
I do appreciate your commitment and enthusiasm, however I believe some comparisons are not entirely accurate or not mainstream equipment. Anyway just some food for thought.
1. Mechanical injection and no EI, well that's every stock Lycoming. Mind you Slick mags have been extremely low quality in the last 8 years, sadly. If you went modern with say an SDS system and it was properly set up (most are not) it will fly with zero mixture input if that is what you want, just like a car, hit the LOP button in the cruise....job done. And no moving parts in the ignition. No Pmag problems.
2. Holy oil burn Batman, 5 hours per quart! You have a problem there, I retired my 2400 hour IO540 (50% more cylinders and oil burn) when it got to 7 hours/qt. 13-15 hours or better is what I see in 390's.
3. No spark plugs.... that's a good point I guess.
4. Forced induction is a handy thing. A TN-IO390 would also be handy, I know where to find one or more.
5. Fuel efficiency. I keep reading this 40% less fuel. So that means 6 GPH vs 10 GPH. I conceded they will be less by volume and by mass, but can I run some numbers as "back of a beer coaster comparison". Using the DHK200 at 75% power with a claimed 8.3GPH and compared that to an IO390 at 150HP also, which should be 9.9 GPH, we have 16.16% less fuel by volume and by mass that is 55.61 vs 59.4 lbs per hour which is 6.38% less.
The big benefit is forced induction with altitude and getting a higher TAS, and yes you can, with a lot of effort turbo normalise any Lycoming/TCM if you wish, but I am keen to learn what the typical TAS is in the 8-12,000' range. Any higher and oxygen is really required and while that is cheap it is not free either. I would advocate using O2 above 8K for longer than an hour anyway, but those levels are quite common I guess. So what do you get?
All the best,
Rv10inOz
My comments are accurate and I stand by them. As for comparisons to mainstream equipment - my comments are generally directed to a ‘stock’ RV14 (although, that’s a moving target). But, I’d wager an SDS system is not all that common, certainly not as much as E-mags or Surefly.
As for your particular points above:
1. I agree, a quart every 5 hrs seems like a lot to me, but Lycoming told me to not worry unless it gets to 1quart every two hours. It’s been this way from zero hours (900 and counting right now).
3. Fuel efficiency. You may have a napkin, but I’ve put a lot of hours on both the DeltaHawk RV14 and the Lycoming RV14. I’ve published the numbers in this thread. They’re real, as is the generally lower cost of JetA vs 100LL. The DH fuel economy, and comparisons to the lycoming, varies based on a lot of factors - power setting and altitude being the two biggest. That’s why in my example above I used a 30% savings as a rough stand-in for overall gains.
4. On the benefits of forced induction and altitude - again I’m not sure if you had a point to make, a question for me, or both. On the latter, I did publish some numbers quite a ways back on performance at 10/11k msl (can’t recall which off the top of my head). The DH KTAS was approx 170 at 65”MP (approx 85” is full throttle). Fuel burn was approx 7.2 gph. I’d get about this same speed from my Lycoming just lean of peak, 2400 rpm, burning approx 10.0 gph.
The DH numbers improve with altitude.
As for oxygen - yes, it’s a cost. I use Pure Meds Inogen O2 generator. About $2k for the unit and one gets unlimited O2 (there are no bottles to refill) to 18k msl. I do mostly XC trips, mostly over mountains, so this set-up was a no brainer for me.
All the best.
Thanks for the info re the oil consumption. I hadn’t asked around enough to know whether mine is abnormal - but, it appears it isn’t.It seems it hit and miss with oil consumption with a 390-angle valve engine or some are not remembering the oil added. Having piston squirters I was told has some bearing on oil consumption but yes, I've talked with several owners of RV's with the 390 av engines and yes 5 hrs. per qt is not unusual. I don't get to much more than that (7-8) and after over 800 hrs compression is still 78+/80 cold. My hangar mates 14 got around 5 and he was convinced he must have glazed his cylinders but after multiple borescope inspections did not see anything. His airframe now has over 1,500 hrs. on it and still has excellent compression. Now if we can only figure out the sticky valve issue.
Congrats on flying this airframe as much as you do. I saw a few months ago one of your longer XC's (Over 7 hrs. West Texas to South Florida non-stop) with a slight tailwind and getting over 180 knots ground speed! Not sure if you have ER tanks but that seems quite a feat! Remarkable. I believe your 30% and thanks for being one of the first to test this engine in RV's.
Didn't mean to be a lurker just nice to see someone flying (over 50 hrs. last 2 1/2 months) and gathering data on a new engine design! I am looking forward to when more complete data will be posted. (As others are I am sure)Thanks for the info re the oil consumption. I hadn’t asked around enough to know whether mine is abnormal - but, it appears it isn’t.
Side note - I have ICAO ‘masking’ so supposedly my flights are anonymous. I’m guessing not so much!![]()
No worries - I was more meaning I apparently haven’t sorted out the whole ICAO protocol as I’m never sure whether it’s actually masking or not.Didn't mean to be a lurker just nice to see someone flying (over 50 hrs. last 2 1/2 months) and gathering data on a new engine design! I am looking forward to when more complete data will be posted. (As others are I am sure)
How many hours have this engine flow in total? Looks like it's been fairly reliable for a new engine set-up.
Rv10inOz
2. Not sure what your point is on the TNIO-390? I’m not aware they’re generally and readily available. But, even if they were the DeltaHawk has significant advantages in fuel economy and simplicity.
All the best.
RV10inOz,Hi Craig,
I will wager there are more SDS systems that never have the problems and failures the E-mags and Surefly have if not by volume by far by percentage.....I get the pleasure of seeing dozens and dozens across experimental and certified aircraft. Those in the know would back me on this. The folk at Superior Airparts here in Australia had a 40% failure rate of Surefly and that lines up with my smaller sample size too. They may be better now, I would SUREly hope so.
Point 2 was merely if you wanted high DA performance you could do exactly that. The TN version does exist but it is not published, and it is a large powerful 4 letter group paid for by your taxes. ;-) I expect it will be available later because it solves that aircrafts DA performance problems.
Point 3........ The sense of humour was lost here I see. Sorry about that. You can take my numbers to the bank. For clarity "Using the DHK200 at 75% power with a claimed 8.3GPH and compared that to an IO390 at 150HP also, which should be 9.9 GPH, we have 16.16% less fuel by volume and by mass that is 55.61 vs 59.4 lbs per hour which is 6.38% less."
Please explain how that is at odds with 30-40% claims? I know how you could fake the numbers for publicity, use the IO390 at full rich and that is a definite 40% saving. For clarity, at a BSFC of 0.56-0.58 and 150HP the fuel burn is 14.1-14.6 GPH, compared to the 8.3 then that is 41-43% saving in GPH for sure. It is not hard to use the red knob and achieve a BSFC of 0.39-0.395 range (commonly called appropriately LOP) and that is what I posted above.
As my dear friends Walter Atkinson and John Deakin would often say, the data has no opinion. In God we trust, everyone else must bring data and it needs to be honest data.
Have a good day.
PS new post today, yet another one https://vansairforce.net/threads/surefly-sim4p-failure.244228/
