Old 03-28-2013, 07:13 PM
Paul Tuttle's Avatar
Paul Tuttle Paul Tuttle is offline
Question I weighed my -8 today, it seems a little heavy to me.
My -8 weighed in at 1121 lbs. Is it just me or does this seem a little heavy?.
Equipment list:
O-360 Lycoming.
Catto 3 blade prop.
Dynon D-100 and D-120.
Radio stack.
Odyssey pc-680 battery.
Classic aero seats.
Hooker harnesses.
Whelan microburst strobes.
fire extinguisher and first aid kit.
ELT.
Painted.
Weight includes engine oil, unusable fuel and brake fluid.
Please let me know what you think.
Thanks.
Paul Tuttle
RV 8
C-FPVT
Flying.
Old 03-28-2013, 07:22 PM
SmilingJack's Avatar
Paul,
After paint (28 lbs) mine came in at 1149
I do have a pretty full avionics suite, 180HP, CS.
John Mastro
RV-8 (SOLD)
10 years of Awesomeness!
Old 03-28-2013, 07:35 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Mine was 1100 lbs before paint - I wasn't working hard to keep it light.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-28-2013, 07:54 PM
drill_and_buck's Avatar
drill_and_buck drill_and_buck is offline
1120 lbs, no fuel, 7qts oil, interior panels and seats, Todd's canopy, grove gear, Hartzel, dual Dynons, PC680, O-360. Not painted.
Mike Draper
RV-8 N468RV
First Flight 11/13/2011
TMX0360, Dual Pmags, CS
Old 03-28-2013, 08:03 PM
vansrv8's Avatar
vansrv8 vansrv8 is offline
Mine is at 1099 on certified scales with similar equipment. I do not think that your out of the ballpark.
Ken
Kens RV8
RV8, Pitts S1C,J5 Hybrid,AcroSport II,RV9A, Chubby Cubby, Custom Supercub Build
Old 03-28-2013, 08:15 PM
panhandler1956's Avatar
1144. Inverted fuel/oil, big 200hp angle valve, heavy Hartzell, extra large smoke system
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 03-28-2013, 09:06 PM
Toobuilder's Avatar
I'm at 1143 with lots of glass in the panel, angle valve, and Hartzell C/S prop...
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 03-28-2013, 09:19 PM
aerhed aerhed is offline
N725CB
O-360 A1A with AFP stock accy
vacuum 6 pack
king com/txp
Oregon Aero sheepskins
bare inside white fiberglass, bare metal
1050 lbs
Actual repeat offender.
Old 03-28-2013, 10:30 PM
KTM520guy's Avatar
KTM520guy KTM520guy is offline
Talking
Clearly your plane is a danger to you and all around you. Your only option is to ship it to me for proper disposal.
RV-8A builder
A&P mechanic
Aviation Plasticized Pigmented Polymer Application Engineer
Old 03-28-2013, 11:41 PM
jimgreen jimgreen is offline
It does seem slightly heavy equipped the way it is. Most of the other responders have metal C/S props which are good for about 50lbs. The Catto shouldn't weigh anywhere near that. You don't mention interior finishing or insulation? That can add up. It's painted but are the gear fairings installed?
In any case it's a fantastic machine. Your gonna love it!
Jim Green
RV7 tip up
IO360 Whirlwind 200RV
