Old 03-27-2013, 10:27 PM
aerhed aerhed is offline
Default On a lighter side.
Anybody need a F1089 elevator pushrod that is precisely one inch too short?
Actual repeat offender.
Old 03-27-2013, 10:45 PM
kevinh's Avatar
kevinh kevinh is offline
No problem. Just put in a little extra opposite trim and build on.
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 03-27-2013, 10:56 PM
If nobodys is building a chopped 10, I suppose I could make an elk call out of it.
Old 03-27-2013, 11:44 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Maybe a -14 builder with the shorter -10 style wing?
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 03-27-2013, 11:49 PM
DaAV8R DaAV8R is offline
Default Look on the bright side
If you were in the construction business it would be 1'-0 too short. We always burn a foot.
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
Old 03-28-2013, 07:51 AM
WenEng WenEng is offline
Default Just add some PVC and build on.
Pound the PVC inside so its stiffer....
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2021
Old 03-28-2013, 08:13 AM
flion's Avatar
flion flion is offline
It looks like the bellcrank is about 2:1, so you could trim a couple of inches from the F-1091 pushrod and be Ok. The bellcrank wouldn't be vertical in neutral position and you might lose a little 'up' travel but that's fine.
EAA Technical Counselor #5357
Old 03-28-2013, 08:56 AM
blahphish's Avatar
blahphish blahphish is offline
Doh! I did a similar thing - I cut the 8' pushrod tube instead of the 6'. That was a nice $50 shipping cost to get a new 8' tube
Brian Unrein
RV10 N42BU 1,000+ hours!
First flight 6-16-12
https://N42BU.com
Old 03-28-2013, 09:30 AM
You know how it happens. I use a tape measure for the long stuff and usually clamp it at the one inch mark to get rid of the error in the end hook and slide rivets. Then you forget to add the inch on the other end. Argggh.
That sounds kind of gross.
Old 03-28-2013, 09:32 AM
J Twilbeck's Avatar
J Twilbeck J Twilbeck is offline
Easy, just buy a pushrod stretcher to pull it back to the correct length. They're sold right next to the bracket stretchers and LH crescent wrenches.
Good luck. Glad I could help....
Justin Twilbeck
RV-10 N521TW
Flying!!
http://buildingrv10.blogspot.com
