Wicks Tach wiring question
We have an older wicks tach, and it seems to only be wired to one mag, what is the proper way to wire a tachometer? Should there be an input on the back for each mag? Currently when you do a mag check only the right mag indicates while the left does not indicate rpm (needle drops to zero).
Any help is appreciated,
Brent
