Dynon Pitch Servo Installation RV-8
Anna
Active Member
Hey Guys!
Some questions to the Dynon Pitch Servo Installation:
- How to fix the Dynon Pitch Brackets at the fuselage? Would you prefer rivets, screws or don?t fix them anyway?
- Did you trim the stringers in the middle section or isn?t it more clever to trim the overdesigned pitch brackets (in the red marked section)?
[/url][/IMG]
- Did you use some AN426AD-4 Rivets (instead of AN470AD) with the left side of the F-635 Elevator Bell Crank to prevent the rivets from interference with the Servo?
[/url][/IMG]
Thanks a lot for helping!
Best regards
Anna
I've installed a few of these. I would not trim the angles and I don't use a washer under the lwr/fwd bolt to provide a little extra clearance, works just fine. (I also installed solid rivets when I replace the brackets.)
