Old 02-16-2013, 06:08 AM
Strike69's Avatar
Strike69 Strike69 is offline
Default Elec System Integration - Comments?
The drawing below is my planned electrical system - VP-X, Garmin G3X EFIS, and dual p-mags. The stick mixer takes the various stick functions from both cockpits and provides one signal (for each function) to the system.
The starter system is a little non-traditional. I am planning a stick starter button instead of the traditional keyed starter. To provide a margin of safety to keep the prop from turning unintentionally/inadvertently, I designed a relay to require both the key to be in and turned to both AND the start push energized and depressed.
Any comments, gotchas, or things i have missed are welcome.
Strike
Mike "Strike" Messer, CFI/CFII/MEI, ATP
RV-8A/F-15E/T-38/T-37/T-6
RV-8A Phase II
N-251WM
Garmin G3X/GTN-650/Dynon D6/GTX-23ES/TruTrak GX Pilot/GDL-39
Eagle XTREEM I0-360-B1HD2 (dual P-mags)
Old 02-16-2013, 09:03 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Seems perfectly "safe" to me - if the extra relays fail, you are "safely" on the ground....
Just remember that the more active components you add to a system, the more potential failure points you have that can prevent the function from operating.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 02-16-2013, 09:17 AM
Snowflake's Avatar
I'd strongly recommend having two buttons that have to be actuated at the same time, one for each hand, if you're pursuing a stick mounted starter. With the keyswitch in the "both" position, where it will live while in flight, your start button on the stick is live full-time, where you could bump it with your hand, knee, AF/D, paper map, iPad, etc. while in flight.
I suggest adding a button to your throttle, to make it fully HOTAS. Or add a button to a bulkhead near your throttle hand, so you can reach it during start. Wire them in series, so you have to push both to get a complete circuit for the starter.
Personally I wouldn't use a keyswitch either. One solid toggle for each mag, and get rid of the flopping keychain during aerobatics.
Oh, and finally, I don't think you want to be starting on "both"... Or is that okay with P-Mags?
Rob Prior
Old 02-16-2013, 09:41 AM
8CW 8CW is offline
The Starter Switch being "Live" in flight is a non-issue. VP-X disables it after the engine starts.
Bill Settle
RV-8 N38CW (Reserved)
Old 02-16-2013, 09:55 AM
Snowflake's Avatar
You'd still want a two-point interlock on the ground before you start. While it's parked, while you're working on it in the hangar, etc.
You want to avoid a single point of failure causing a safety issue... In a conventional setup, you have to accidentally turn on your master, and then accidentally turn your keyswitch to "start" to turn the prop. Two things have to "fail," and at least one is unlikely (turning a key by accident).
In the proposed setup, I believe the start button is unprotected on the stick. So if you're in the cockpit working on something, and accidentally hit your master, your starter is now live with an exposed pushbutton to activate it. Depending on which button it is, it might not even be prominently marked. How many people sit in a cockpit and grab hold of a stick like that, and immediately wonder "what do these buttons do?"
Rob Prior
Old 02-16-2013, 11:35 AM
az_gila's Avatar
az_gila az_gila is offline
Question
What is the advantage to having a stick mounted start switch?
Or is it "Because I Can" ?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-16-2013, 06:07 PM
Snowflake's Avatar
Having a pushbutton on the throttle and one on the stick and requiring that they both be pushed for start ensures that your hands are where they should be (at the controls) during startup. Stick back, throttle positioned, etc. I'd like mine set up that way but don't have a throttle that's conducive to a pushbutton.
Also, while flying, a relight is quicker if you don't have to let go of the controls and find the starter on the panel. Perhaps useful for people flying aerobatics or formation.
Rob Prior
Old 02-16-2013, 08:20 PM
Ironflight's Avatar
A relight? these are not turbine aircraft, and getting the prop to actually stop takes extraordinary actions on the part of the pilot. I can think of an incredibly unlikely set of events that would make it necessary to actually crank the engine in the air if it quit - just restore fuel or ignition, and it should go - the prop will already be turning.
Paul
Paul F. Dye
Old 02-16-2013, 08:49 PM
N941WR's Avatar
N941WR N941WR is offline
There is no issue with starting an engine with P-mags on "both". The ignitions retard the timing to TDC when below 200 RPM. This means when the first cylinder fires, the engine is over 200 RPM and the timing moves to its operational setting. The “operational setting” is dependent on the timing curve selected.
Here is one question, do you want both of your ignitions to go through the VP-X? I have no experience with this system but you might want to think about putting your P-mags on traditional pullable breakers.
Two things to keep in mind regarding the P-mags; first, make sure to run the ground wires from Pin 1 to an engine case bolt and don’t use the same case bolt for both P-mags. Second, you might want to think about running serial data lines from the P-mags into the cockpit somewhere and terminate them with female DB-9 connectors as we describe on page 33 in the EICommander manual. That way, if you ever want to program them, you can plug your PC into them one at a time, without having to remove your cowl. Also, if you want to run the “A” curve, you can just put a jumper in male DB-9 connector and plug it in, no need to de-cowl.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-17-2013, 06:33 AM
Strike69's Avatar
Default Feedback
Bill - thanks for the explanation on how the p-mags work. I think there is a lot of confusion over this type of e-ignition with the number of systems that DO require a continuous electrical supply, while the p-mags do not. Once the p-mags reach ~900 RPM they are generating their own power internally. I have no issues with putting both p-mags through the VP-X. It has a Dual Buss architecture and the only time it would be a problem is during the start. If something is wrong with the VP-X preventing the start, I don't want to be flying anyway.
On the starter switch, I went with the stick mount for the aforementioned reason and because I can. I didn't want to use the traditional key start since this grounds the right p-lead and as explained, both p-mags are used for start resulting in a more efficient/smoother (and quicker?) ... so I understand.
Thanks for all the great comments. I have gained a few additional thoughts and tweaks to the system.
v/r
Strike
RV-8A Phase II
N-251WM
