Old 02-09-2013, 05:24 AM
bobmarkert's Avatar
bobmarkert bobmarkert is offline
Default How do I drill between wing wall ribs conduit?
Using the search function for ?conduit? ?Rib Holes? (etc. etc.) flooded my computer with a ton of posts but no solution for my dilemma. I need to drill conduit holes (3/4?) in my wing ribs that are already riveted to the front and rear spar. No issues until I got to the wing walk ribs which are too close to allow the unibit and 90 degree drill in. I can?t be the first to have this problem. What new tool do I need to buy :-)
Solutions/suggestions appreciated.
Bob Markert
Littleton, CO KBJC
Reserve Grand Champion Oshkosh 2016
Renegade Opposing Solo pilot and other Dirty Odd Jobs
http://www.rmrairshows.com/
2021 dues paid
Old 02-09-2013, 05:40 AM
FredMagare FredMagare is offline
Default Unibit Extension
A great little tool to have: http://www.averytools.com/prodinfo.asp?number=9605
But I used it just once. Perhaps you could find someone local who has one and would be willing to loan it to you?
If not, buy a smaller angle drill and flex the ribs a bit to get in there to drill. That's a tool you'll need from time to time.
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL&I, A&P
Frederic.magare "at" gmail.com
RV-9A Finishing
Old 02-09-2013, 07:43 AM
Rick_A's Avatar
Rick_A Rick_A is online now
I remember doing this on my QB wings, which was even more difficult. I used a unibit extension, but one that I found locally. I also customized my unibit.
All the unibits I had produced too large a hole if I ran it all the way through - so I could reach the next rib. My solution was to buy a cheap unibit at Harbor Freight and grind off larger diameter steps in the unibit.
This way the max size of the unibit was equal to the desired hole size. This way I was able to use the extension and move from rib to rib without too much hassle.
Rick Aronow,
Flying 7A Slider;
RV-12 SOLD
Jacksonville, FL
Old 02-09-2013, 07:52 AM
bobmarkert's Avatar
Thanks Fred and Rick. I DO owne that extension tool and will grind my unibit down today. I love this site....... build on!
Bob Markert
Littleton, CO KBJC
2021 dues paid
Old 02-09-2013, 09:49 AM
bret's Avatar
bret bret is offline
I got creative with extensions on the QB wing.
Old 02-09-2013, 09:50 AM
aerhed aerhed is offline
Don't grind your unibit. Slip it into place and then put the extension on. Drill your hole then take it apart. You only need to do it a couple times.
Actual repeat offender.
Old 02-09-2013, 10:42 AM
larrynew's Avatar
larrynew larrynew is offline
Or get a 3/4 unibit. Saw this one at Home Depot. http://www.parts-express.com/pe/show...number=362-105
Larry New
RV-7A - Built, flew 950+ hrs, sold
RV-10 - Built, flying 250+ hrs
RV-12iS - All kits ordered!
VAF on Annual Autopay
Old 02-09-2013, 10:58 AM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
Most of the times that I need a 3/4" hole in aluminum sheet, I use a spade bit intended for wood. But only the ones with points on the corners of the spade seem to work in that application.
Bob Kuykendall
Low-drag wingtips for RV-4 through RV-8
EAA Technical Counselor
Old 02-09-2013, 01:18 PM
GLPalinkas's Avatar
Looks like Bob already has the solution but for those yet to come down this road.....
I used Lowe's Aviation supply extension and ground down a unibit to fit the Lowes's underground sprinkler system tubing (Light weight).
Venice, Fl
Old 02-09-2013, 01:22 PM
bobmarkert's Avatar
Thanks guys. I could not see the forest for the trees. This was so simple it's embarrassing. Just 5 minutes with a grinder and I was done.
Again you came through!!
Bob Markert
Littleton, CO KBJC
2021 dues paid
