Old 11-20-2012, 07:43 AM
prkaye prkaye is offline
Default how often re-grease wheel bearings?
As per subject. How often do you guys clean and re-grease your wheel bearings?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 11-20-2012, 07:50 AM
tommylewis's Avatar
tommylewis tommylewis is offline
Default my rvs
I always repack wheel bearings at the annual condition inspection. I know that is sooner than necessary, but then I don't have to remember when I did them last.
Tom Lewis
RV7a N967BT 2040 hrs.
RV10 N143EB 1050 hrs.
Granbury, Tx
https://maps.findmespot.com/s/WYQQ#history/assets
Old 11-20-2012, 07:56 AM
Sam Buchanan's Avatar
been here awhile
Phil, I'm not trying to ignore your question, but I clean/pack the bearings when they need it. That means sometimes they get it at condition inspection, sometimes they don't, and sometimes it is when I am flipping tires between condition inspections. The wheels come off the plane at least once a year for inspection or tire flipping and the bearings get inspected each time (rotate by hand to check for roughness) but cleaned and greased only as needed. After you fly your plane a while you will get a feel for how often this is necessary.
After 13 years and 1100 hrs, I'm still on the original bearings.
Sam Buchanan
RV-6
Old 11-20-2012, 08:11 AM
Ok, so you just visually inspect the bearings for dirt and grime? I admit, in over 2 years of flying I have yet to take mine apart and look at them
Phil
RV9A (SB)
Ottawa, Canada
Old 11-20-2012, 08:23 AM
My A&P has me clean and repackage at each condition inspection.
Old 11-20-2012, 08:31 AM
rocketbob's Avatar
I have modified my Rocket axles and wheels to use an amphib bearing kit, and have a zerk on the axle. I can regrease in seconds, and do it more often since its easy to do. With a little bit of work a RV axle could be modified to do the same.
Bob Japundza CFII A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 11-20-2012, 08:42 AM
been here awhile
There probably isn't a one-size-fits-all answer to your question, but I suggest you take a look at your wheel bearings. If they are not showing any sign of wear, grease is still clean and hasn't started drying out, and you don't want to clean/repack every year, service the bearings and then service based on condition instead of time. But at least look at them each year. Some will say it doesn't take much more time to clean and regrease......so, whatever is your preference.
I've never found dirt and grit in my bearings but this could be dependent on where a particular plane is operated.
Sam Buchanan
RV-6
Old 11-20-2012, 09:37 AM
rv8bldr's Avatar
rv8bldr rv8bldr is offline
Hey Phil
I do mine every annual inspection.
Mark
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk (C-GPFG reserved)
Flying a '79 Maule M5-235C
Ex-military : Donated anyway (it's worth it)
President EAA 245 Ottawa, ON
Old 11-20-2012, 10:30 AM
JonJay's Avatar
JonJay JonJay is offline
At risk of sounding like a childrens book; I follow Sam, Sam I follow I am....
(Sam is on my short list of "experts" that if I see respond to a post, I read it. Mel, Dan, Iron, Walt, etc... I read em....)
I pack them when the wheels are off if they need it. Out with the old grease, in with the new. I believe the bulk of any contaminant will depart with the old grease. I do completely clean and inspect them every few years.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 11-20-2012, 10:35 AM
RV6_flyer's Avatar
Ditto.
I do likewise. I repack by hand every time I change tires. As needed when ever the wheel is off. I stay away from solvent as much a possible and only use it IF it needs it.
Gary A. Sobek
NC25 RV-6
Flying
3,500+ hours
Where is N157GS
Building RV-8 S/N: 80012
