Old 10-24-2012, 02:47 AM
skyyking skyyking is offline
Default Canopy cracking when pulling rivets
Folks, I am worried when I go to pull the AACQ-4-4 rivets on the canopy frame it will crack the canopy. As you are aware, you can't control the pressure. I need to ask therefore; if any of you out there have had any problems, especially on the forward portion of the canopy frame where the rivet makes direct contact with the plexi.
Thanks!
Old 10-24-2012, 02:55 AM
lucaperazzolli's Avatar
lucaperazzolli lucaperazzolli is offline
clean everything, deep breath, HOT plexy canopy, slightly deburr holes, run slowly, everythings will go !
Warm the canopy !!!!
2c
Luke
Trento, northern Italy
RV-8 QuickBuild, Catto 3 blade Prop, YO-360-A1A. Status : I-LUKE is Flying - 400 h. and counting
http://www.rv8.it
CrewRV8 team leader
https://youtu.be/VhAkhuqZMQA
https://www.youtube.com/watch?v=he9AFHRO1OY
=VAF= 2021
Old 10-24-2012, 03:10 AM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
I hear that the rivets crack the canopy when:
  • You don't use the correct rivets (which are particularly "soft")
  • They are "old" (=hardened)
When we did ours, had no issue, avoiding above. Of course, you will have plenty of spare plexi and AL, so do some practice with some spare riverts if you are not confident
As Luke says, "slightly deburr" holes. We went one further and used fine sandpaper to polish the holes such that the "countersink" corners were all smooth...
Andy
Old 10-24-2012, 07:59 AM
aerovin aerovin is offline
I just did all those on my RV-8 canopy. OAT about 90 degrees. No problem and after I did a few I could anticipate when the rivet would pull and held the puller accordingly.
Scott Thompson
RV-8 N9324Z (flying as of 8/30/15)
http://www.aerovintage.com/rv8/rv8-index.htm
Old 10-24-2012, 08:25 AM
MarkW's Avatar
MarkW MarkW is offline
Like Andy says. You will find that the recommended rivets require very little pull pressure. It therefore puts little pressure on the plexi.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 10-24-2012, 11:28 AM
flyboy1963's Avatar
Default WHY does it crack?
The times I've pop-rivetted plexi, a crack occurred when the rivet flared in the hole, not from the actual pulling together of the plexi to the support.
that said, be sure they are in TIGHT contact, and if you have used a washer or shim of any kind, ensure the rivet length is correct so it flares in the tube, not in the washer, or you get a false 'pull', and it may come out later.
all the comments on the warm or hot plexi, deburring and fresh rivets I'm sure are valid....remove any stress points.
I'd be concerned if the canopy were 5 or 10 years old also, as it hardens with age, or if stored in light or at hi temps, the moisture and/or plastic resins leach out in some way. ( IMO)
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 10-25-2012, 09:39 AM
12vaitor 12vaitor is offline
I also did the sandpaper polish after countersinking the holes. I also wet set all of the rivets with proseal before pulling them. All work was done in 90+ temps, so hopefully the future cracking potential is low.
Old 10-25-2012, 10:24 AM
Mel's Avatar
Mel Mel is offline
As others have said, first make sure you use the correct rivets.
They should be aluminum!
Use a hand puller, NOT a pneumatic puller. That way you CAN more easily control the pressure.
I've done many and have never had a problem.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-25-2012, 11:48 AM
jimbower jimbower is offline
I know this is not about rivets, but I used no rivets in my canopy...everything is #6 screws, no cracks.
Jim Bower
St. Louis
RV-6A (flying)
Old 10-25-2012, 12:30 PM
rvpilot's Avatar
rvpilot rvpilot is offline
Default Could go rivetless....
And glue it! No holes to drill, no rivets to pull.
Plenty on the forums about this!
Bill Waters
Based KCVC (Covington, GA)
RV6A - Gone, but not forgotten!
RV8 - Gone too, now winning races in the RV Gold Class!
RV4 - Flying!!!
