Old 10-12-2012, 08:09 PM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Airworthiness Inspection
Today I had a representative of the local FSDO perform the airworthiness inspection on my RV-8. I think he walked around the airplane at least twice if not more, crawled underneath on a creeper, peered in the front and rear baggage areas with a flashlight, jiggled this and that, etc., etc., had me demonstrate flight controls and flaps... looked over the engine with a magnifying glass, peered intently at any movable connection (flaps, ailerons,, rudder, elevator).
He climbed in the airplane and studied the instrument panel, circuit breaker panels and checked all the flight controls.
As he sat there he said "I know if I keep looking long enough I can find SOMETHING!'
In the end he said I should label the rear seat mic and phone jacks and the PTT switch right above them. He complemented me on doing an excellent job building. I was a happy camper.
I thought I would get a temporary on the spot, but he said because of scheduling and travel it would take him two weeks, and he also took my application for a repairman's certificate. I know this is different from what I've read here on the forum, but all I can do is say "Okey-Dokey". Besides, I still need some taxi tests and I'm not in a hurry.
I'm quite happy I got both the nod and a compliment. It was a good day.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 10-12-2012, 08:19 PM
scsmith scsmith is offline
Default Good on'ya
Congrats.
You are on the threshold of enjoying all the fruits of your labor, and it is a marvelous airplane.
Be very careful with taxi tests. Many bad outcomes.
More important to have pilot currency and transition training. Then get it up and away from the ground quickly. There, you have time to sort things out.
Better to intend to fly, get some altitude and have to deal with an emergency than not intend to fly and find yourself learning to land a new airplane in a highly dynamic situation, not a stabilized approach, and not in landing config.
Its a proven design, so not much new can be learned in a part-power taxi test.
Just My humble opinion.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 10-13-2012, 06:27 AM
pierre smith's Avatar
Steve gives good advice, Don.
Congratulations,
Rv10 Sold
46 years ag pilot/CFI
Air Tractor 502/PT-6
Building RV-12, Wings, fuse, emp complete. FWF in progress.
Old 10-13-2012, 07:48 AM
cfiidon's Avatar
Default Roger that
My taxi tests will be "slow speed"... just to check out brakes, steering, yada yada yada.
I just had some time in an RV8 and it's time to get my feet back to dancing with some more tailwheel currency time.
I'm aware of the dangers of high speed taxi tests... not advised by many.
Don
Old 10-13-2012, 09:48 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Congrats!!
Don
Don, big congratulations to you.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-13-2012, 12:42 PM
If you have in motion insurance make sure it is valid without the paperwork in hand.
Old 10-13-2012, 02:50 PM
cfiidon's Avatar
Default Confirmation
Bob,
Confirmation of Insurance Coverage is in hand.
Don
Old 10-13-2012, 03:03 PM
Skykingbob's Avatar
Default AWESOME!!!
Don,
CONGRATULATIONS.....MANY HAPPY FLIGHTS!!!
YOL BOLSON!!!!
Bob "Skyking" Corriveau
RV-8 QB Reserved N212KB
ATP
CFI/CFII/MEI
Old 10-13-2012, 04:59 PM
Rupester Rupester is offline
Default BIGtime congrats to ya !!!!
I know how exciting that is. I got my ACertif on 8/30/12 .... it was a big, big day.
I did 1.4 hrs of taxi tests (slow) to test exactly the things you mentioned above. You have to do some run testing before the DAR gets there, if nothing else to get idle speed and mixture set and to have some idea how it taxis, in terms of brakes and the free castering n-wheel. I had 350 hrs in Cessnas and Pipers with steerable nosewheels; free castering is quite a bit different. A little practice is a good thing.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 10-13-2012, 08:20 PM
cfiidon's Avatar
Default Thanks
Thanks all! I have the pressures set nicely, along with the idle settings (borrowed a good 0-30PSI gauge). Things can change though and it'll be interesting to see during slow taxi how engine temps affect everything. I have plenty to do to keep me busy until the paperwork is done.
Don
