Old 09-03-2012, 06:06 AM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Default Fitting Wings
I'm just getting started on fitting the wings and am confused right off the bat (not a new condition). On the instructions (page 8-24, last full paragraph), it states that I need to mark on the W-804PP (bottom inboard wing skin) the screw locations at each unused rivet location on the bottom flange of the W-810 root rib. The only problem is that there are no unused rivet locations and when I went back to drawing 17 to see if I needed to drill some rivets out, there was no notation about leaving holes open on the bottom skins. There are open locations on the top skins, but none on the bottom skins.
Can anyone clear this one up?
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
https://www.marksrv8.com
Old 09-03-2012, 07:07 AM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Been there...
Mark,
The bottom skins seem to have rivets installed when they should be open. Simply match the top holes and drill out the corresponding hole on the bottom. If I recall, there should be about seven places. You'll be drilling out the rivet and replacing it with a nut plate.
I was able to drill them in place using a home made square I could slip in. I subsequently used #8 clip nuts rather than remove the wing and rivet nut plates. I don't think it saved any work though in the long run. It was simply a personal choice to try and I was successful.
If you have sufficient assistance, I'd pull the wing and do it according to plan.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 09-03-2012, 08:07 AM
RV8MW RV8MW is offline
Mark,
I just did this you have to mark 3 inches back towards the wing tip with a felt pen on the bottom wing skin to the open rivet holes that should be open. It is the last row of rivets and there is several of them and you will have to mark them with the wings off. Then when you mate the wings you can make the mark back 3 inches and drill the holes in the bottom fuselage skin then take the wings back off and add plate nuts. I drilled them with a very small bit then went up to the right size. If your rivet holes are not open you will have to drill them out. You could use a hole duplicater if you already have the wings mounted. The mark is just to help you locate where the holes are in the wing skin.
MIKE WARREN
RV8 N184MW RESERVED
TMX-IO360 REDGOLD,HARTZELL CS
CLINTON N.C.
www.mykitlog.com/mwarren
Old 09-03-2012, 09:33 AM
I found Matt Dralle's page where it looked like every other rivet was open on the bottom side. On the top side it's one open, two close, one open, two closed. Is there a way to verify this today? If not, I'll call Van's tomorrow and ask them why their plans aren't correct.
Old 09-03-2012, 07:36 PM
vmirv8bldr's Avatar
vmirv8bldr vmirv8bldr is offline
Default Get the updated drawing from Vans
I had the same issue, and called the manufacturer. They said "Oh, yeah, what's your email address, we'll send you the updated drawing." Sure enough, the new drawing shows the open holes plain as day.
Bart Filipiak
Eastvale, CA
RV-8 N74VB
Barrett IO-390
WW200RV
FLYING!!!!!!!
Old 09-04-2012, 12:45 PM
Wouldn't it be nice if they would put updated drawings on line in a restricted "builder's only" section? Even with their "new website", it's still so 1990s.
Old 09-04-2012, 02:30 PM
ctbecker ctbecker is offline
Must be a common problem this weekend. My drawing 17 only shows 12 rivet locations on the bottom of the wing, but there are actually 21 holes. I just assumed - it appears correctly - that the holes not shown on the drawing are for platenuts. However, if it hadn't been for the recent service bulletin on wing installation, along with the drawing which showed a platenut on the bottom, I might have made a much different assumption. As it was I marked the holes in the bottom fuselage skin with a hole duplicator, drilled with a number 40 bit and hit every hole. Then enlarged for the 8R8 screw.
Charlie Becker
N464CB. RV8A(es)
Certificate Issued
Old 09-04-2012, 02:42 PM
Now that's interesting. I am sure that I don't have 21 holes on that rib. Compared to the top skin, it appears that they skipped every other hole. I wonder if that's where the nutplate holes are supposed to go? The plot thickens. Of course, my kit is an old one from '99, so who knows how many changes have been made to this drawing? I am waiting on them to get back to me in email with the answer and the updated drawing.
Old 09-04-2012, 09:34 PM
Mark,
I checked mine tonight and I had marked and drilled ten holes on each side. That was every other rivet location. I then drilled two more at the aft end.Hope this helps.
MIKE WARREN
RV8 N184MW RESERVED
CLINTON N.C.
