Old 08-28-2012, 02:28 PM
Echo Tango Echo Tango is offline
Default I don't know why it took me so long to think of this *PIC*
Works like a charm!
cost: $1.35
Old 08-28-2012, 03:05 PM
Wayne Gillispie Wayne Gillispie is offline
Okay...What is it? It better be RV related. Ha.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 08-28-2012, 03:06 PM
scard's Avatar
scard scard is offline
Yep. I use old pieces of bicycle tube.
Scott Card
CMW E-Lift
VAF Advertiser
Mhead's Avatar
Mhead Mhead is offline
I have wasted a lot of time using masking tape in different locations as needed. This is a great idea, thanks for sharing!
Gary Moore
Northwest Arkansas
Working on panel and wiring
RV-7, N742GM
Donated 11/10/20
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
I haven't built an RV, but I'm guessing it's a bucking bar with O-rings around it to facilitate picking up from a table, and holding in use??
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 08-28-2012, 03:12 PM
hadn't thought of that. i was going to put some tape on my bar, but as i live about a block from a hardware store, i figured... why not an o-ring?!
i got some that were just a little wider than a set -3 rivet shop head (the rubber compresses while riveting) and i just set about 75 rivets without a single bad rivet! the two o-rings stabilize the bar and keep it flush against the flange i'm riveting, space it far enough to prevent marring, and allow me to kind of just hold it there loosely against the web/flange (it orients itself)
highly recommended
Old 08-28-2012, 03:13 PM
yes i put the third one on there for gripping. it's nice that you can move them around as well depending on what needs riveted/orientation of the bar
Old 08-28-2012, 03:18 PM
one could conceivably get different thickness o-rings for different rivets sizes. basically eliminates slipping off of a rivet head as the rubber compresses while the rivet is set, but still holds the bar's orientation against the work piece while protecting against over-driving the rivet.
also makes it easier to pick up/hold. (and set down)
Old 08-28-2012, 03:29 PM
Buggsy2's Avatar
Buggsy2 Buggsy2 is offline
Great idea. Get a wide variety of O-Rings from Harbor Freight.
Ralph Finch
RV-9A QB-SA
Davis, CA
Old 08-28-2012, 06:18 PM
panhandler1956's Avatar
Definitely a good idea! I hated that masking tape mess I made on all my bucking bars.
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
