Old 07-19-2012, 04:02 PM
Jeff R's Avatar
Jeff R Jeff R is offline
Default Another first flight, part 2
Yesterday was the first flight of my RV-9A, done by transition-training instructor Jan Bussell at the controls. Today was my first sole attempt.
I seem to be experiencing plug fowling and I nearly aborted my first takeoff when, during the runup, I had some deep mag drops (I have both a regular Slick mag and a PMAG). Drops on both were about 250 RPM! I consulted with the old timers and two A&Ps who felt I needed to run the engine hard and lean it out (even though I lean aggressively on the ground). Let me add I have a new Lycoming YIO-320, though it has been sitting around for several years.
I did what they suggested and the mag drops dropped to a more reasonable 125 RPM on each mag. I still would have expected the PMAG to show little drop, but it was about the same as with the Slick. Anyway, with some degree of nervousness (more over my own abilities and not with the engine, since it had flown fine the previous day and I am sure Jan would have picked up on any anomalies), I took to the runway, said a little prayer, and applied full power. Before I knew it I was airborne, with all the awe and excitement that come after 5 years of building and 47 years of dreaming. I was actually flying my own airplane!
The engine was running smooth, but very quickly the cylinder head temps, especially on #1, started rising, going to 425F pretty quickly. Jan had told me of this. I kept the nose down, climbing at an anemic 400 ft/min or so at 100 KIAS. Both #1 and #2 peaked at 429F, with #3 and #4 about 5F cooler. Finally, the temps started retreated and, as I circled above the airport at about 1,600 feet (scattered Cu keep me from going higher) they settled at a little below 400F. At full power and full rich, I was showing 2,400 RPM and, IIRC, 9 gal/hr fuel flow, and the Skyview showing 70% power, which was just about right. I kept the engine running wide open until it was time to land.
I circled the airport, trying to get used to the Skyview. The manual pitch trim was very sensitive. It took just some small turns to make significant pitch changes. I was trying to figure out on the display where level flight was, finding the flight path predictor to be right on, but not the artificial horizon line. It can be adjusted, but I didn?t bother. At full power, I was showing about 130 KIAS (I didn?t have the wheel pants or fairings installed), and I stayed between 1,600 to 1,800 feet, with the base of the clouds not all that far above me. After about 30 minutes it was starting to get bumpy and it appeared more clouds were moving in so I decided it was time to land.
I descended and entered an upwind at pattern altitude. (One thing I tried to be aware of was Va, which really isn?t all that high. I caught myself at 136 KIAS and pulled back the throttle back to get closer to Va. It wasn?t that it was turbulent, it was more that I was trying to develop a good habit.) Jan had instructed me to go to idle at mid-field downwind, slow down to flap speed, add some flaps and turn base, adding more flaps and RPMs as needed. He recommended I fly my final at 65 KIAS. Well, I was concerned about going to idle and, short story, I flew downwind and base more like a Cessna, and ended up high and fast. Of course, I had to do a go around. (I could probably have slipped it in, but that would be foolish to try on a first flight.) Back on downwind, I still didn?t go quite to idle, maybe 1,200 RPM, and since several planes were lined up for takeoff, I extended my downwind a bit (and inadvertently widened my approach) to allow one of them to take off. I was still a bit high on final and so I added full flaps and finally went to idle. No problems with the engine and with a speed of 65 KIAS, she started coming down nicely. Passing the runway threshold in a stable approach, I was getting excited as I thought I was going to grease it on, but then she didn?t want to land! It was like my baby was telling me that after 5 years, she didn?t want it to end yet! She kept floating just a few feet high, which I guess 9?s like to do. She finally settled down as she ran out of airspeed (no, I failed to notice the speed). Not a greaser, but not bad, either. I held full back pressure and used little breaking, using up the remainder of the runway (3,600 total length) before turning off. I am thinking an approach should be flown even slower, but until I can get enough altitude to do some stalls, 60-65 KIAS is what I will use.
I already admitted to some nervousness. One can?t help but think that when you go up in your airplane for the first flight that the odds of your having a bad day are probably about the highest they will ever be (for most of us civilians anyway). Having the training with Jan helped immensely. Flying glass is certainly different, though, and it will take a while to figure out all that the Skyview has to offer, and my flying in a Skycatcher helped there. Having a few dozen hours of hanger flying really helped, but a dynamic display is different than a static display. Let me add the aural warnings the Skyview puts out gives some peace of mind. It alert me to the high cylinder head temps and even gave a warning that I was exceeding my flap extension speed (I was on 10 degree flaps and really wasn?t, but the warning sure was nice.)
It is a great feeling to finally be flying and to finally be one of those posters here who gets to announce their first flight in their own airplane. To those still pounding rivets, it is all worth it. Every drilled finger, every toe that felt a dropped bucking bar, the black and blue legs from hitting the steps, tank sealant?. everything, it was all worth it.
I loved building and, of course, I want to build again. It is just that the -9 is close to the perfect airplane for me, so what else would I want to build/fly? But, I still have wheel pants and fairings to do, and a paint scheme to figure out, so no new projects until this baby is done!
The RV grin!
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 07-19-2012, 04:51 PM
ArVeeNiner's Avatar
Congrats! Don't it feel good? Now, get up there again!!
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
Old 07-19-2012, 05:10 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
I had a tendency to let the airspeed in a 7A with a Skyview get too low on final. I must be used to knowing a position on a steam gauge airspeed indicator.
Old 07-20-2012, 06:32 AM
bowenjola's Avatar
bowenjola bowenjola is offline
Big congratulations Jeff!!! Great to see another 9A in the air and glad to hear Jan is still training! I had my transition training with him late last September and first flight 10/4/11. 70 hours now and it is great! Still flying without paint and gear fairings/pants...maybe this winter I'll get to it.
John Bowen
Mansfield, Ohio
RV-9A Flying!
Old 07-20-2012, 07:46 AM
Skykingbob's Avatar
Default Great!
Jeff,
Enjoyed the sequel!!! Congrats....again!!!
Bob "Skyking" Corriveau
RV-8 QB Reserved N212KB
ATP
CFI/CFII/MEI
Old 07-20-2012, 09:02 AM
turbo's Avatar
turbo turbo is offline
nice going. hope to see you around south florida this fall.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 07-20-2012, 11:22 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
Congrats Jeff!
Since I'm only about 5 hours ahead of you, this caught my eye...
Since you are at a relatively low altitude (1600 ft), full throttle would, I think lead to both a higher fuel flow and a higher power % setting. I've typically flown at about 4500ft. Even at that altitude, 70% is with the throttle pulled a fair amount back.
FWIW, my cylinder heads do about the same as yours--#1 and #2 get hot on climb (peaking in the high 420s) but then drop right down into the 360's to 370's in cruise, and my #3 and #4 tend to stay up in the 400's to 410's. Am assuming they'll drop once things get broken in. Am experimenting with foil tape for air dams to get the aft cylinders a bit cooler but even in the 420s, they are well below the recommended temps in my Lycoming manual where it recommends keeping them below 435 (in sustained operation) for longest cylinder life.
Anyway, congrats again.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 07-20-2012, 07:02 PM
izzybear's Avatar
izzybear izzybear is offline
Default CONGRATULATIONS!!
Congrats - and I love the combination "RV grin" with the hands in the air! An exclamation mark on the first flight for sure.
Jim
RV-8 N223GT (reserved)
Finish - arrived 10/7/15
Fuselage - arrived 3/14/14
Wings - arrived 3/7/13
Builder # 83331
www.mykitlog.com/izzybear
VAF Dues gladly paid up till December 2020
"The ultimate responsibility of the pilot is to fulfill the dreams of the countless millions of earthbound ancestors who could only stare skyward and wish." - Unknown
Old 07-22-2012, 07:10 AM
airman airman is offline
Hey Jeff
Congrats on your first flight!!!
Mike
RV6A
