Old 06-27-2012, 09:44 PM
ScottSchmidt's Avatar
ScottSchmidt ScottSchmidt is offline
Super Moderator
Default Fuel Tank Calibration
Today I tried to do the fuel tank calibration and my voltage is stuck at 5 volts. When I measure the resistance of the float it works just fine. Has anyone else seen this?
I have the Skyview with the conversion harness (meaning I received my wiring over a year ago and decided to wait for the Skyview).
When I look at the screen that has the setup information, it is set to "resistivity", yet the calibration page displays 5 volts. I don't quite understand what it is doing there.
Scott Schmidt
Salt Lake City, UT
RV-10 N104XP (1280 Hours)
RV-12 N321UT (Sold)
Old 06-27-2012, 09:57 PM
Mich48041 Mich48041 is offline
It sounds like an open circuit. The problem could be the wire from the panel to the fuel sender. But a more likely cause is that the sender is not grounded. The mounting screws should have lock washers with teeth that will bite through the proseal and ground the sending unit to the tank.
Joe Gores
Old 06-27-2012, 10:01 PM
Measure the voltage from ground to the wire on the fuel sender. If it is 5 volts, then the sender is not grounded or it is defective. Well, in your case it is not defective because you already checked it with an ohmmeter.
If the voltage is zero, then there in an open circuit somewhere between the sender and the instrument panel.
Joe Gores
Old 06-27-2012, 11:32 PM
Super Moderator
Default Thanks
Thanks, I will check that out tomorrow and let you know.
Scott Schmidt
Salt Lake City, UT
RV-12 N321UT (Sold)
Old 06-28-2012, 05:40 AM
Dave12 Dave12 is offline
What Joe said. Install the ground and forget about it.
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Old 06-28-2012, 05:51 AM
BigJohn BigJohn is offline
This is a common problem. See this post.
John Peck, CFII, A&P, EAA Tech Counselor, Flight Advisor.
Master Pilot Award, UFO Member.
RV-12 N37JP 120176, built 2011, sold 2020.
One Week Wonder Build Team, OSH 2018.
Old 06-29-2012, 07:11 PM
Bill_H's Avatar
Bill_H Bill_H is offline
Be sure you are calibrating the correct tank! See this thread, post #138 and some after that. http://www.vansairforce.com/communit...d.php?p=643487
Old 06-30-2012, 12:26 AM
Super Moderator
Default Ground worked
I installed the ground today and everything worked perfect.
Calibration went well.
Thanks guys.
Scott Schmidt
Salt Lake City, UT
RV-12 N321UT (Sold)
