Old 04-25-2012, 04:21 PM
glenn654 glenn654 is offline
Default Master Cylinder O-rings
I have Cleveland master cylinders 10-30 and the o-rings are now leaking because of the 83282 brake fluid and the old nitrile seals. I failed to replace them when I upgraded the caliper o-rings.
I need to replace them with Viton rings but need the correct sizes to order.
Does anyone know off-hand the correct sizes or part numbers?
Will probably order from O-ringUSA
Glenn Wilkinson
_____________________________________________
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
2015 Donation Gladly Paid
"Maintain Thy Airspeed, Lest the Earth Arise and Smite Thee"
Old 04-25-2012, 11:47 PM
RVJeff RVJeff is offline
Default Master Cylinder O-Ring age
Hey Glenn,
Just curious how old and how many hours you have on your rig with those o-rings and Mil 83282 hydraulic fluid. That stuff is supposed to be completely compatable with systems designed for Mil 5606, as in standard buna-n o-rings.
Nothing wrong with Viton rings, I think that buys you higher temp limits.
I have 365 hours and 4.5 years on my RV-8 with Mil 83282 hydraulic fluid from Royco with stock Cleveland wheel brake calipers and Matco brake cylinders. Haven't seen a drop of red come out of either due to deterierated o-rings or seals. Brakes are good and tight and haven't rebleed them since new. Maybe next annual though. Wonder what gives with your setup. I'm curious to hear the conclusions and outcome since quite a few of us have chosen to use Mil 83282 fluid. Thanks, pal. Let us know.
Jeff Liebman
RV-8 N139JL
365TT on the Hobbs
Superior IO-360 Hartzell BA Prop
Airglades Airport, FL
Old 04-26-2012, 05:35 AM
chaskuss chaskuss is offline
Glenn,
I have 2-110 & 2-113 listed as the sizes of the older Cleveland style master cylinder O-rings. FYI, no need to upgrade to Viton on the master cylinders or parking brake valve, as these parts do not see slightly higher than ambient air temps [unlike the calipers] Simply replace them with Nitrile O-rings, which can be found almost anywhere. FYI, do NOT use Harbor Freight or any other "Made in China" O-rings. Made in China [I'd avoid anything made in a third world country. Best to buy Made in USA] O-rings are of sub standard quality.
Simply remove your old O-rings and take them to match them up to the replacements.
Charlie
PS The new fluid had nothing to do with the O-ring failure. They simply wore out. The newer fluid is fully compatible with the original Nitrile O-rings. You should be able to source Nitrile O-rings locally from an auto parts store or your local industrial bearing supply house. These days, you never know the quality of small parts like O-rings found at an auto parts store. My experience has been that the bearing supply houses carry good quality stuff.
Old 04-26-2012, 05:55 AM
turbo's Avatar
turbo turbo is offline
i just happen to have replaced my caliper oring and took a pick of the package for my last spare oring from aircraft spruce. not the route you are planning but may help others lookn for a spare. i had a spare puck on hand so installed it also at over 4,000 hrs on the original puck. it was a messy job but went quickly. i plugged the brake line after removing the caliper and prefilled the caliper before installing and bleeding from the bottom up.
TURBO YES =VAF= Payed Jan2021
Ed D'Arcy
RV6-A 5,300+ hrs, R-44 1,600 hrs, Helicycle traded for 33 FFR coupe, 300 young eagles flown
Stuart, Fl / East Hampton,Ct / Virgin Gorda, BVI - villa sold.
addicted pickle ball player
Old 04-26-2012, 06:51 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default Upgraded Caliper Piston/Pucks - Parker-Cleveland
I have the new upgraded style caliper pistons with Viton orings as a set for $48. I can email you a pic of what happens to the original design and you'll want to get them out of there.
I understand you're looking for Master Cylinder orings... while your messing with brake fluid, this would be a good time to deal with the caliper piston issue to.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Default Wrong part
Ed,
He's asking about master cylinder O-rings [specifically the older Cleveland units] not caliper O-rings. Vans used to supply Cleveland master cylinders and calipers. They later switched to Matco master cylinders due to cost increases of the Cleveland units. Not sure if they are still using Cleveland calipers on the newest kits?
Charlie
Old 04-26-2012, 08:35 AM
RV6_flyer's Avatar
Would love to see what the Upgraded style caliper pistons look like.
Can you post both the old and the new upgraded style caliper pistons here?
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 04-26-2012, 01:49 PM
To answer RVJeff et al.
The master cylinders are approximately 20 yrs. old and 344 hrs, I've been flying since '03. I upgraded to 83282 brake fluid about 3 or 4 years ago and thought it was incompatible with the nitrile o-rings and is why I wanted the Viton o-rings. But since that is not the case I can get the replacements more easily.
I guess they were just worn out. Still plyable but outer sides flattened.
Thanks for the info.
Glenn Wilkinson
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
Old 04-26-2012, 03:59 PM
Email Sent...
Reiley
VAF# 671
Friend of the RV-1
Old 04-26-2012, 08:11 PM
gasman gasman is offline
It sure would help more than one person....................
VAF #897 Warren Moretti
2020 =VAF= Dues PAID
