Old 03-25-2012, 02:06 PM
Stewie Stewie is offline
Default Why not expensive die grinders?
Hi all-
I just purchased a Sioux angle drill and love it already. I was thinking about tool quality, and was wondering why builders spend a fair bit on drills, rivet guns etc but I have not seen people recommend good quality die grinders in the "recommended tools" threads? Just curious - it's a tool that I use as much as, if not more than any other.
Eric
Eric Stewart
=VAF= dues paid 2016
facebook.com/TheSR1Project
Old 03-25-2012, 04:15 PM
Walt's Avatar
Walt Walt is online now
I have a Dotco dye grinder, it's one of my most used sheet metal tools and well worth the $$.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
Old 03-25-2012, 04:32 PM
roee roee is offline
A die grinder is not a high precision tool, and doesn't need to be in order to perform its function well.
I use a $20 die grinder from Harbor Freight and it seems to do its job just fine.
In what way is a $400 die grinder so superior to a $20 one to be worth the price difference? Just curious.
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 03-25-2012, 04:33 PM
ROTARY7 ROTARY7 is offline
Default Dynafiles are worth their weight in gold
A good die grinder is a must. Like a lot of tools, one that will last a lifetime is worth the cost. To me anyway.
The air tool I personally think is worth its weight in gold is a Dynafile (or equivalent brand). The model I have is: Dynabrade 40320. I was just using mine today, on some alligator jaws for upcoming tools for Hondajet. The unit accepts 1/4" - 3/4" belts.
I was telling a friend today how useful these are. You can change out belts, and switch quickly from sanding to polishing. It is readily throttleable, and you can really turn the belt slowly for great control. I like to hold mine so that the belt throws the debris away from me. This isn't a cheap air tool, but you will use it ALL THE TIME.
There are electric versions out there too. Dynafile is the gold standard.
http://www.aaabrasives.com/products/...x-457-mm-belts
Mark Swinford
Aeronautical Engineer
RV-7 N65NX
Old 03-25-2012, 04:36 PM
Default Well, it has to be good enough to do the job
I have a good die grinder that I inherited from my brother Drex and when I need it it does the job perfectly - I used it last night to put a groove in the edge of a part for a perfect fit into a small space at the end of an installation. But, I don't use it often and when I'm done the part that I am working on is the important thing. If the tool allowed me to do the necessary work like this spinning variable speed manual tool has done that's all I care about. Tools like rivet guns and especially electrical pin and terminal crimpers predetermine the quality limit of the product and therefore demand more of my attention in tool selection.
Bob Axsom
Old 03-25-2012, 04:46 PM
Walt's Avatar
Mark and I think alike...
I'm gonna have to keep an eye out for a Dynafile now
Old 03-25-2012, 04:54 PM
KTM520guy's Avatar
KTM520guy KTM520guy is offline
I have an old (at least 30 years old) Dotco die-grinder. It's smaller and lighter than any of the cheaper tools out there. Even with it's worn out gear set it will run newer grinders into the ground.
RV-8A builder
A&P mechanic
Aviation Plasticized Pigmented Polymer Application Engineer
Old 03-25-2012, 05:11 PM
Default die grinder?
I had to look up what a die grinder even was! I have never used one before I started my build. After the tail kit is nearly complete, I still haven't used one. I did buy a fake Dremell kit from Costco, but I haven't opened the box yet.
I do have a really cool tool that fits on my angle grinder with a couple of chains on it for carving wood, but I probably won't use it on the plane either! I will look at the posts and the links and see what the die grinder works well for. The one with the mini belt sander looks like it could have a bunch of uses.
That is one of the fun things about building, finding more tools.
Old 03-25-2012, 05:48 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
I agree that quality tools are great, but if one has certain budget constraints, might go this route and buy avgas with the $408 difference...
http://www.harborfreight.com/air-belt-sander-97055.html
Just sayin'.
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 03-25-2012, 06:01 PM
paul mosher
Posts: n/a
Default Grinder
As a professional aircraft mechanic I would never spend more than $20 on a die grinder. I've had expensive ones and they work no better than a Habour Freight cheapee. They usually last about a year in an industrial environment. (I'm speaking of heavy check chasing lots of corrosion job).
Drills, ect I would go for the high quality stuff.
