Old 03-15-2012, 05:58 PM
gasman gasman is offline
Default Final word on AD's from the FAA
Hot off the press!!!!! http://www.eaa.org/news/2012/AC%2039-7D.pdf
Wait......... nothing is ever final with the FAA!!
VAF #897 Warren Moretti
2020 =VAF= Dues PAID
Old 03-15-2012, 06:00 PM
DCat22's Avatar
DCat22 DCat22 is offline
Probably worth moving this out of test.
Saw this in an EAA email today, as well...
Basically, seems to say, they don't apply to Experimentals, unless specifically called out that they do.
9. APPLICABILITY OF ADs. [...] Unless stated otherwise (see subparagraph 9b of this AC), ADs only apply to type-certificated (TC) aircraft, including ADs issued for an engine, propeller, and appliance.
b. Non-TC’d Aircraft and Products Installed Thereon. Non-TC’d aircraft (e.g., amateur-built aircraft, experimental exhibition) are aircraft for which the FAA has not issued a TC under part 21. The AD applicability statement will identify if the AD applies to non-TC’d aircraft or engines, propellers, and appliances installed thereon [...]
Seems to make sense to me.
-Rick Greer, VAF #2492
Old 03-15-2012, 06:07 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Done, now in General Discussion.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-15-2012, 09:09 PM
Nitty's Avatar
Nitty Nitty is offline
Default ECi Cylinder AD
So will the FAA now come out and revise past AD's to specify whether or not they apply to experimentals. I'm wondering because I have 4 ECi Group B cylinders that I will need to replace in 50 hours using the warranty application process. Would ECi then reject it saying that this AD doesnt apply to experimental aircraft and if I want new cylinders, I can expect to pay full price?
Old 03-15-2012, 09:25 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
Interesting and timely. This debate has raged for some time on this and other forums, and it is nice to finally have some official guidance. I'm afraid, however, that it will not quiet all debate on the subject. For example, as I read it, not a single AD issued from the dawn of time until today could be applied against an RV, as none of them (to my knowledge) were written with inclusive language of 9(b). Anybody else agree with my interpretation?
Jeff Point
RV-6, RLU-1 built & flying
ATP, CFI, Tech Counselor, Flight Advisor & President- EAA Chapter 18
Milwaukee
Old 03-15-2012, 09:50 PM
rocketbob's Avatar
This AC is not worth the paper its written on. AC's are not regulatory. As long as FAR 39.3 is written the way it is, all AD's apply. I take that in the future they will be less ambiguous on the language used in writing new AD's as they apply to experimentals.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 03-16-2012, 12:59 AM
erich weaver's Avatar
I agree with what others are saying here. Additionally, I don't necessarily agree with EAAs interpretation of the AC as being a big win for experimentals. The application of ADs to experimentals can be helpful when it is used as a hammer to get the manfacturer to replace / repair their defective product at no cost or reduced cost to the aircraft owner. When they do not specifically state that they apply to experimentals, it can conversely be used by the manufacturer as a means of avoiding responsibility. The ECI cylinder AD is a case in point. The AD is written to indicate it applies to Lycoming engines with ECI Titan cylinders. So, what about an engine built by Aerosport Power instead of Lycoming, but still using ECI Titan cylinders? Somehow those are outside of the AD? I don't think this new AC clears things up at all.
Erich
Old 03-16-2012, 02:47 AM
DCat22's Avatar
Hmmmm...
If I build a plane, say "Rick's Super Plane" and later sell it. Can I later, myself, (try to) issue an AD that the new owner must follow?
Old 03-16-2012, 07:18 AM
Hmmmm...
The manufaturer doesn't issue the AD, so the answer is no. However, you could request that an a safety issue be reviewed and an AD be issued. By doing so, you would make yourself liable for an future design/manufactuing defect in the plane. By requesting the AD you are basically accepting responsibility for the safety of the aircraft.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
I donate every year on my B-Day (in Dec)
Old 03-16-2012, 07:41 AM
Walt's Avatar
Walt Walt is offline
I agree with Bob and would not want to argue the point in front of a judge.
I suspect the standard boiler plate verbology will change to include experimentals in future AD's. Time will tell.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
