Old 02-29-2012, 07:12 PM
MC2's Avatar
MC2 MC2 is offline
Default Tank Leak and Green Peanut Butter
Old 02-29-2012, 07:25 PM
tkatc's Avatar
tkatc tkatc is offline
Looks good man! I hope you are finally leak free.
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
Old 02-29-2012, 07:38 PM
bhester's Avatar
bhester bhester is offline
Thumbs up Fuel Tank Repair
The Fuel tank repair looks great!
Would have been a great time to do the Service Bulletin
http://www.vansaircraft.com/pdf/sb06-2-23.pdf
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2021 VAF donator - alot better than any magazine subscription
Old 02-29-2012, 07:43 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I believe that the line of sealant on the bottom exterior of the rib shown here, would have been better if applied to the inside of the tank while you had the access cover off.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-29-2012, 07:44 PM
Greg Arehart's Avatar
Maybe too late for you, but I covered the nutplates on the inside of the sender with proseal (and I mean completely covered) as added insurance.
Greg
Greg Arehart
N 7965A
Old 02-29-2012, 08:45 PM
Steve Barnes Steve Barnes is offline
Default You must have done something wrong...
because your resealing job looks too clean and tidy.
GOOD JOB
Steve Barnes "The builders Coach"
Old 02-29-2012, 08:50 PM
erich weaver's Avatar
Why would fuel leaks turn Proseal into a gooey mess, as described? It IS supposed to seal the fuel in after all.
Also, in past threads it has been recommended to let the Proseal partially cure for 24 hrs before placing the cover plate back on, installing the screws, and letting it fully cure. For next time, I guess.
Erich
Old 02-29-2012, 09:07 PM
Kyle Boatright Kyle Boatright is online now
Erich
That is what I was wondering. Bad batch of proseal? Out of date proseal? Poor mix ratio? Ethanol in the fuel?
If fuel will turn the proseal around the sender plate to goo, it'll do the same to the proseal that forms the fillets on the ribs and seals the rivets. That's a nasty thought.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-01-2012, 04:08 AM
Captain Avgas Captain Avgas is offline
Yep Bobbie, that was bad miss. You might just have ruined Mardy's day.
You’re only as good as your last landing
Bob Barrow
RV7A
Old 03-01-2012, 08:04 AM
Boy, you look at the craftsmanship of the before and the after and you really get a good idea of the range of building ability in this hobby. Well done.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Last article: "Gonna Finish This Sucker" (Kitplanes)
Waiting for the avionics kit (backordered: chip shortage)
