Old 01-05-2012, 08:47 AM
Dgamble's Avatar
Dgamble Dgamble is offline
Default Engine mount bolt/cotter pin
When torqued to 160 in-lbs, the top engine bolts are far enough into the castellated nuts that it seems as if the cotter pin doesn't have a full grip:
Considering that the cotter pin will still keep the nut on the bolt, should I leave it as-is, or try to find a washer to shorten up the bolt a little bit?
Dave Gamble
Grove City, OH
RV-6 N466PG Purchased already flying - SOLD!
The Book: The PapaGolf Chronicles
Built RV-12
http://www.schmetterlingaviation.com
The Book: Schmetterling Aviation
The above web blogs and any links provided thereto are not instructional or advisory in nature. They merely seek to share my experiences in building and flying Van's RV airplanes.
Old 01-05-2012, 09:18 AM
edsong's Avatar
edsong edsong is offline
Default Washers
Yes, thick or thin washers are used to place the castle nut in the right position to accept the cotter pin.
Edson Grindeland
Hatton, ND
RV-8 Flying
http://www.hattonflyingcircus.com
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Old 01-05-2012, 09:19 AM
islandmonkey's Avatar
islandmonkey islandmonkey is offline
A washer certainly would help here in adding more meat for the cotter pin to be surrounded by. For my own peace of mind if I had this issue, I would add one and redo with a new cotter pin.
Anthony Johnston
Brit working in Zurich, Switzerland.
1500 hour pilot and ex instructor and examiner.
RV-4 s/n 4572 Emp Kit.
RV-3B s/n 11460 Emp Kit. (In storage).
Anthony's RV-4
Old 01-05-2012, 11:29 AM
Bruce Russell Bruce Russell is offline
I had this exact problem. After a gentle suggestion by my DAR, a washer of the appropriate size centered the hole in the nut.
-Bruce
Bruce Russell
Clayton, GA
Simultaneous Repeat Offender
RV-14A 140005
N48WT
Old 01-05-2012, 01:42 PM
Dgamble's Avatar
It's still easily accessible - no reason not to.
Dave Gamble
Grove City, OH
Built RV-12
Old 01-05-2012, 02:08 PM
rv6rick's Avatar
rv6rick rv6rick is offline
What Anthony said.
Also, for those folks who are reading that might consider showing their plane at Oshkosh....the Judges will absolutely mark down if that castle nut was displayed same as in the pic.
Rick Gray on the Chesapeake Bay - Builder Assist Center - 50+ Awards & counting
BRONZE, SILVER & GOLD LINDY AWARD WINNING RV's & Rockets
EAA Oshkosh Homebuilt Judge/Tech Counselor/Flight Advisor FAST Formation Flight Lead
Kitfox/RV4/6/7/8/9/10/12/14
2 Time SunínFun Grand Champion
F1 Rocket #1 Oshkosh Gold Lindy Grand Champion!
F1 Rocket #2
Fastback Slider RV8 -Lindy Winner
RV14 #2 flying
RV10 #7 in progress
55 RV's & Rockets
WW Prop Dealer
Love my Pitts S1S
Old 01-06-2012, 09:26 AM
rampilot rampilot is offline
Dave- That looks like the top engine mount and my iteration of plans call for a AN960-616 washer to back the nut on the top two mounts (no washer is called out on the bottom two mounts). I hung my engine last night... Here's mine without the cotter pin installed torqued to 160 in/lbs and even with the washer it looks like it could still use another.
[IMG][/IMG]
The same is true for the other top mount. The bottom mounts appear to be fine. Is it acceptable to stack two washers there behind the nut? Or do you guys recommend putting the additional waster on the bolt head side?
Thanks!
ram
RV-12 #459
230hrs
Old 01-06-2012, 10:46 AM
I would put the washer on the nut side. A washer on the bolt side would change the effective grip length of the bolt.
-Bruce
Bruce Russell
Clayton, GA
RV-14A 140005
N48WT
Old 01-06-2012, 11:50 AM
Dgamble's Avatar
I ordered some -616 and 616L washers last night. The thin L washers should allow a little fine-tuning if required.
Dave Gamble
Grove City, OH
Built RV-12
Old 01-06-2012, 12:20 PM
At $.04 each... Wonder what the shipping will cost...
ram
RV-12 #459
230hrs
