Old 12-06-2011, 08:14 AM
riobison riobison is offline
Default My knee is killing me ?Theater Knees or Chondromalacia?
After being out of flying for 6 years I want to get back into it and I?d like to get into a Vans or a Rocket.
I?m suffering from what my Doctor calls Theater Knees or ?Chondromalacia? After a couple of hours sitting in my Viper my right knee is killing me and I need to get out of the car.
Of the Van?s AC what one would allow me to have a straighter leg extension? The more my knee is bent the worse it is. If I wrap my knee and pull the knee cap to the side this does help and gives me maybe another 30 mins or so. I?m 54 yrs old at 5?11?, 205 pds decent shape and I still lightly exercise 5 days a week. I?m thinking the 30 years of heavy weight training has done its damage and now I?m paying the price.
I like the centerline seating of the RV4 or the RV8 but maybe the side by side would be better.
Anyone out there suffering from this and what are you flying?
Tim
Old 12-06-2011, 08:31 AM
Jamie's Avatar
Jamie Jamie is offline
Hi Tim:
Although never officially diagnosed, I used to suffer from the same thing.
You are very close to my size (6'0" and 192lbs). I can stretch my legs all the way out in my -7A. The great thing about the side-by-side RVs is you can turn a little sideways if necessary to stretch out your legs. When I'm solo and in cruise I'll frequently move my right leg over to the other side and stretch out.
I would recommend that you go sit in an RV that has been configured for someone about your same size.
Old 12-06-2011, 09:10 AM
aarvig's Avatar
aarvig aarvig is offline
I suspect the side by side seating arrangement of the 6, 7, or 9 would provide you with better leg extension/more area for your feet to go.
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
Old 12-06-2011, 09:11 AM
aarvig's Avatar
Don't push on the gas pedal so hard.
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
Old 12-06-2011, 09:29 AM
N8RV's Avatar
N8RV N8RV is offline
Tim, after years of abuse and surgeries, my knees are seldom happy with me either. I have an -8 and have to move my legs around quite often to avoid cramping up. There's enough room between the rudder pedals for me to extend my legs (one at a time, admittedly) and prevent problems. I certainly wouldn't rule out a tandem model for that reason.
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
Old 12-06-2011, 10:07 AM
Dan92 Dan92 is offline
Tim, When I was about your age I had the same problem. Although I never had it diagnosed by a doctor, I could not fly a long time without pain in both my knees. Someone suggested taking the joint supplement glucosamine so I started taking it on a daily basis and no longer have that problem. Check with your doctor and see if he thinks that is a good idea. It may not work for you but then again it may.
Dan
Old 12-06-2011, 10:11 AM
Rick6a's Avatar
Rick6a Rick6a is offline
....I like the centerline seating of the RV4 or the RV8 but maybe the side by side would be better.....
Tim,
I am fortunate to fly a side by side (-6A) and a tandem RV (-8). While either configuration is comfortable to me, I do prefer the optional cockpit adjustable rudder pedals I installed in the -8. Sometimes you just want to stretch out your legs. Some guys say the cockpit adjustable option is not really needed because (they assume) that once the pedals are adjusted to suit, are rarely moved from that position. WRONG. On a whim, in cruise flight I can pull on the lanyard and shove the pedals forward to stretch out my legs. At 5'9" I am not all that tall so when the pedals are against the firewall, I can just barely reach them. But thats okay because that forwardmost position frees up the floor space and allows me to straighten out my legs fully which as you know can provide temporary relief for aching knees. I suggest that before you pull the trigger on a specific RV model, do yourself a favor and check out the cockpit adjustable rudder pedal arrangement for yourself.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 12-06-2011, 10:46 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
I also have intermittent knee pain, and the glucosamine and condroitin really helps for me.
Good luck
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-06-2011, 10:53 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
IMHO, The adjustable rudder pedals in the -8 ought to be standard, not optional.
In the RV-8 in my avatar, the owner is around 6'4" and flies with the pedals nearly all the way forward. I have short legs and need to have them full aft. The adjustability is a godsend.
There is a lot of legroom in the -8 with the pedals full forward. I'm only 5'7" and with the pedals full forward, my feet cannot reach them.
Neal Howard
Airplaneless once again...
Old 12-06-2011, 10:54 AM
Phil's Avatar
Phil Phil is offline
Hmm... I have never heard of that before, but the description tells me all I need to know. I have the same issue. I just never thought of getting it diagnosed.
I'm 6'2" x 230 and despite my frame, I really like to be up close to the controls. If I'm driving, I'm up closer to the wheel than you think. If I'm flying I'm further forward than you think. I just don't like being away from the controls and reaching out. I can feel the vehicle more if I'm up on the controls and not sitting back with my limbs extended near their limits.
But this has resulted in a lot of knee pain over the years. I can temporarily relieve it by sliding my seat back and extending my legs, but if I can get out and walk for a good 15-30 minutes I'm good.
I learned something today. I don't think you can get more room than the RV-10, so that's a good thing for me.
