Old 10-17-2011, 11:11 AM
TomVal's Avatar
TomVal TomVal is offline
Default How to remove wing walk material???
The material is adhered to a painted surface. What is the best technique in removing the material and also the adhesive from the wing?
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered (Sold)
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 10-17-2011, 11:41 AM
Geico266's Avatar
Geico266 Geico266 is offline
Use a hair dryer / heat gun to carefully warm up the area and peal it off. Use 3M adhesive remover to get the remaining glue off. It will not damage the paint. Available at any automotive paint store.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 10-17-2011, 11:52 AM
TomVal's Avatar
Thanks Larry!
Tom
Tom Valenzia
RV8 (Sold)
Old 10-17-2011, 12:15 PM
Geico266's Avatar
Originally Posted by DAGO View Post
Thanks Larry!
Tom
I like to use a hairdyer over a heat gun. Heat guns get too hot IMHO. If you are careful they are fine, but too much chance for error working on a painted surface. My wife does not mind if I use her hair dryer..... if she doesn't find out.
Old 10-17-2011, 12:25 PM
Greg Arehart's Avatar
Mineral spirits will usually take off a lot of the adhesive as well and shouldn't harm paint. DO NOT use acetone.
greg
Greg Arehart
N 7965A
Old 10-17-2011, 02:43 PM
TomVal's Avatar
greg
Thanks again guys for the advice. Larry, I'm glad you suggested a hairdryer versus the heat gun because I was about to head for the "gun".
Tom
Tom Valenzia
RV8 (Sold)
Old 10-17-2011, 09:03 PM
Glas467's Avatar
Glas467 Glas467 is offline
I have also used a product called "Stripe Eraser" I got from a local automotive paint shop -- it's basically a solid rubber type material, about 6" in diameter and 1" wide that you can use with a power drill. Does not damage paint at all and strips off both the material and the adhesive without use of any chemicals. It's used in the auto world to remove vinyl decals & striping, worked like a champ for me.
Old 10-17-2011, 09:19 PM
mcencula mcencula is offline
Default WD-40
I have used WD-40 to remove decals from cars with no damage to the paint. It's a slow process...drip it along the edge, peel a little, repeat. Works well if you don't mind taking some time.
Mike Cencula
RV-7A (fuselage)
www.our7a.com
Betcha my pile-o-scrap is bigger than your pile-o-scrap.
