Go Back   VAF Forums > Main > Safety
Closed Thread
Old 10-14-2011, 01:35 AM
Toobuilder's Avatar
Default BIRD STRIKE! I'm an ace.
I've had a few birdstrikes before, but tonight takes the cake.
Perfect evening to fly. I run over to Rosamond to get some gas for our trip to Chandler tomorrow. Upon my return to my home strip I perform the customary "low approach" to check the sock. Fairly low power, only about 165 knots - done it a million times... At the departure end, just as I start to pull for the downwind, I see the sunset blackened by a flock of birds fleeing the area. I duck just in time to save my eyes from shattered plexiglass and bird carcasses. After the "boom" I raise my head to see the large hole in the windscreen and blood and feathers all over the cockpit. As I pull into the left downwind I feel the blood running down my head... A hand swipe confirms that I'm bleeding. Logic tells me that even a small cut on the head bleeds profusely, but I still hope that I don't pass out from shock before I can get the thing on the ground. As it turns out, the approach and landing are non events and it is only when I shut the engine down in front of the hangar that the adrenaline really kicks in. In the aftermath it looks like I'm out one windscreen vs. three quail in the cockpit plus two more in the engine . I guess that makes me an ace, and very lucky to have my sight and life. Time to re-evaluate the value of the "low pass" to check the windsock. On the upside, I was looking for an excuse to do a flat wrap windscreen...
Go ahead and tell me how dumb the "low approach" is... I'm in no mood to argue.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 10-14-2011, 01:47 AM
ao.frog ao.frog is offline
Default No argueing here but...
.... CONGRATS of a job well done! You kept your calm, you never forgot to FLY THE PLANE and got safely on the ground. That's the way to do it.
Too bad about the plane ofcourse, but a windscreen is easier to replace than your life.
Very quick thinking: to duck to save your eyes!
And now you'll soon have that flat wrap windscreen too, nice bonus!
Lastly; congrats of beeing an ace too! I bet VERY few of the ace-pilots during WW II did their five kills ON ONE MISSION....
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 10-14-2011, 02:10 AM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
Go ahead and tell me how dumb the "low apprach" is...
No need to, you've already told yourself
Everything is a fun / risk / cost / luck balance, and the combination of 165K and sunset seems to have tipped tipped the balance
The one lesson one might take, and borne out by military experience, is that a helmet / visor combination would have reduced the risk of inury to you to almost nil - the windscreen would take most of the energy, and helmet visor protect you from the remaining energy, and added windscreen fragments. To do it properly, you would need a clear as well as tinted visor, and always use at least the clear (those were the RAF "rules"). Whilst I now do 99% fly with a helmet, for canopy clearance I only have the dark visor fitted, so will use your experience to really try and use it when low / fast.
Out of interest, was it a standard Vans windscreen?
Andy Hill
RV-8 G-HILZ
RV8tors
Old 10-14-2011, 02:18 AM
Toobuilder's Avatar
It is my understanding that this is the second windscreen fitted (following an ill placed grab to get out of the cockpit). I think it's aftermarket, but I don't know the supplier.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
Old 10-14-2011, 02:39 AM
Geico266's Avatar
Geico266 Geico266 is offline
Glad you are okay! A new windscreen, a couple Flintstone bandaids, a little glass cleaner, and a new pare of undies life is good!
Nothing better than a good quail dog and an over under on opening morning chasing a covey. Never thought about using the RV.
Good job flying the plane after the incident. I would guess it was a tad distracting having a hole in front of you with blood all over. Well done.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 10-14-2011, 02:43 AM
scsmith scsmith is offline
Default Only quail?
If a quail can do that, imagine a turkey vulture, or a sea gull, or a crow!
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 10-14-2011, 05:11 AM
pierre smith's Avatar
Default Wow!
Michael...it's just great to see you alive!
In my ag business, bird strikes are fairly common and I always duck and flinch.
FWIW, I learned a long time ago, that when a bird is near the ground and gets startled, it'll jump up..(of course...it'd be suicide for him to dive)...happened to a friend in his -4''split the wooden prop and dented the gas tank but he managed a pattern with a shaking engine and made it.
Thanks the good Lord!
Rv10 Sold
46 years ag pilot/CFI
Air Tractor 502/PT-6
Building RV-12, Wings, fuse, emp complete. FWF in progress.
Old 10-14-2011, 05:20 AM
FredMagare FredMagare is offline
You should definitely stencil five quail on the side of you plane!
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL&I, A&P
Frederic.magare "at" gmail.com
RV-9A Finishing
Old 10-14-2011, 05:21 AM
terrykohler terrykohler is offline
Default Lucky Guy
Glad the outcome wasn't worse. Really appreciate you posting the pictures. More than mere words, these really drive home the point about adding unnecessary risk to the things we do. You might want to take this one step further, and forward both your print description and pictures to EAA and AOPA. If anyone there has an intesest in safety, they'll get printed.
Thanks again for having the courage to shine a light on yourself.
Best,
Terry CFI
RV9A N323TP
Old 10-14-2011, 05:56 AM
mv031161's Avatar
mv031161 mv031161 is offline
Hey Pierre...do you think the 1/4 prop cone paint works on birds as advertised? I had it on my Pitts and saw a few close calls and big birds dive....I have not painted my prop cone in the Giles just yet but i have an LED wigwag landing light ON all the time when bellow 2500 agl?
Does anything works at all?
Mitch V.
Semi-Retired in Tybee Island GA
2007 MX2 Nigel Lamb EX RBAR MX2 (Current)
2020 MX2 New Kit Position (Sold at OSH to Team RV Member)
2009 Team Rocket F1 (Sold)
2008 MXS Green Slime"(Sold)
2007 MX2 Patches" (Sold)
1999 Giles 202 "Primal Fear/Perucho" (Sold)
1965 PA32-260 "God Bless America" (Sold)
2003 RV6 "Airhawk One" (Sold)
Closed Thread
