Old 10-12-2011, 08:53 AM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Default Move day...last sunday
Well last Sunday was the big Move day. Came about a year earlier than I planned due to we bought a new house and didn't want to move the plane twice in a year. I also have spent the last month or so building a hangar door with the a help of a friend at the airport. (it doesn't take that long, but I was very busy and only could get to the airport once or twice a week to work on it) Was a lot a work, but worth it in the end. Bought the hangar door hardware in instructions from The Ulitmate Hangar Door.
After looking around for trailers to borrow I ended up renting a 26' Uhaul truck and was able to get the wings and fuse transported in one trip...but I forgot to get pics of that.
Ryan Allen, CFI
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 98%, Working on Finishing Kit, AEIO-540 on the stand
Acro Sport 2 on deck.
Old 10-12-2011, 09:01 AM
cjensen's Avatar
cjensen cjensen is offline
Nice work Ryan! Congrats on the move!!
Chad Jensen
Astronics AES, Vertical Power
chad.jensen@astronics.com
920-216-3699
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 10-12-2011, 09:15 AM
boom3's Avatar
boom3 boom3 is offline
Looks great Ryan! You'll love having the man door.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 10-13-2011, 07:52 AM
Jerry Fischer's Avatar
Jerry Fischer Jerry Fischer is offline
Default The big move
Hi Ryan,
Nice facility. I'm about to move mine which is just about the same config. How did you load the fuselage into the U-Haul? Is the hydraulic lift the way to go? Thanks for the help and speaking of help how many folks did it take to load the plane and unload it? I would like to learn from your experience.
Thanks for any advice,
Jerry
Jerry Fischer KW4F
VAF# 1646
USS Randolph CVS-15 V-6 Div. AT2
RV7 N364SJ Miss Sandy sold
RV1 N1583 "Mockingbird 1" SOLD
EAA volunteer SNF
HBC volunteer/co-chairman OSH
Tech counselor
Old 10-13-2011, 08:11 AM
miyu1975's Avatar
In the Uhaul I first loaded the wings that are in the cradle..see pic. then I loaded the fuse tail first until there was enough clearance to close the door without hitting the nose. Plently of room. I straped everything down with ratchet tie downs (8 of them). A friend of mine happened to have a set of 2x8 x 10ft wooden ramps...I used the two ramps for the wheels and rolled up the fuse, which was the tricky part. Not much room for err. 3 people involved, my wife guiding the tail and me and another builder on each leg pushing up the ramp, making sure enough clearance on the ramp was there. Unloading was easy...took not even 10mins to unload. Also, I parked the Uhaul at the bottom of my drive so that the hieght of the truck was lower to the ground. did that same at the airport for unload... Would have been even easier with a tommy lift gate. Hope that helps..good luck
Ryan Allen, CFI
E-170/175
Old 10-13-2011, 12:31 PM
Default move
Thanks Ryan that's a huge help
Jerry
Jerry Fischer KW4F
VAF# 1646
EAA volunteer SNF
Tech counselor
