Old 06-27-2011, 12:02 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Default Wing Torque Tube WD-1014C Part
On section 23-5 for the assembly of the torque tube collars, it references part WD-1014C. But I have no such part. I do have a black tube of the right diameter that is about 24 inches long. It's too long to fit on one side. I read on another builder site that perhaps this pipe is correct but needs to be cut to make the two WD-1014C parts (one for each side). Is this correct? To what length should these be cut to make the parts? There is no reference in the instructions at all.
https://skydrive.live.com/embedphoto...ed26&sc=photos
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 06-27-2011, 01:28 PM
rleffler's Avatar
rleffler rleffler is offline
I can remember my frustration when I got to that page, but my memory doesn't recall the specific solution. My best recollection is that I cut the bar in half. Dry fit afterwards and if it's still too long, you can trim to fit.
I do recall that when I had to install the assembly, I had to take the bolts out and compress the overall length to get it installed, then pull the ends back to position once in place. I think the first one took me an hour and the second took five minutes.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 06-27-2011, 01:58 PM
Auburntsts's Avatar
Auburntsts Auburntsts is online now
Same deal -- I had a moment of panic when I couldn't find that part, too. Then I figured it out like you did that it was that unlabeled 24"ish length of steel tubing. Just like Bob, I simply cut it half and no further triming is required because of the way the 1014 is fitted to the torque tube collars.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 06-27-2011, 06:37 PM
sstellarv10 sstellarv10 is offline
Yes, cut in half and the final length is made with the collars on and you are clicking the collars. Page 23-6 fig 4
Steve Stella
#40654 Finishing
N521RV reserved
Old 06-27-2011, 08:09 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
I actually called Vans and they shipped me the part, which was the black 24" tube that you simply cut in two!
Bill Peyton
RV-10 - 1250hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 04-03-2016, 01:27 PM
ERushing's Avatar
ERushing ERushing is offline
Default I love this forum!
Like the title says - I love this forum. I spent 45 minutes this morning going through all my bins looking for a WD-1014C powder coated tube of indeterminate length. I passed over that 24" black tube 5 or 6 times. "Nah... that couldn't be it. The manual says that it's powder coated." Every time I looked at the manual, my mind read WD-1014PC, not WD-1014C.
Frustrated.... take a break... eat lunch... check the forum. Ah ha! others have run into very similar frustration. Problem solved!
Back to building!
Eric Rushing
RV-10
90% done, 90% to go.
Looks like an airplane!
Molalla, OR
Old 07-10-2016, 04:10 PM
rdamazio's Avatar
rdamazio rdamazio is offline
+1 - I didn't have trouble realizing what the part was (because the BOM that came with the kit points to that tube as "W-1014C makes 2"), but I was left wondering what length to cut it to - thanks!!
Rodrigo Damazio Bovendorp
San Jose, CA
RV-10 builder #41623
Build log at http://www.airplane.build/
VAF dues paid
Old 07-22-2016, 11:49 AM
WrightsRV7 WrightsRV7 is offline
Default part labeling...
Clearly a line in the instructions would help in saying that "WD-1014C" is prepared by cutting a metal stock pipe (7/8" dia x 24") in two equal sections. Mine was a little less than half with still lots of edge distance. I think we assume a WD- part is powder coated, or at least "welded". This part is simply a metal stock part with no powder coat or welding, so not typical at all. We have high expectations for Vans for sure.
Old 07-22-2016, 11:57 AM
JackinMichigan's Avatar
JackinMichigan JackinMichigan is offline
Default I painted mine... bad idea..
I constructed the assembly using the bare steel tube. Afterward, I painted it cuz it looked bad, and I figured it would rust.
THEN... as I started to assemble the wing, I had to remove the bolts at one end and shove one assembly towards the other, meaning I had to shove one of the assemblies over top of the paint I had added.. so I had to sand off the paint.. I guess you live and learn.
Old 07-22-2016, 12:35 PM
DRMA DRMA is offline
I had the same issue in identifying that part this week. Thank goodness for VAF!
Regarding painting of the tube, the instructions say it should be primed inside and outside before final assembly, which will be my next step in this section of the plans.
Dave
