It says to roll the skin with a piece of 1/2 pipe. I already have the bearing eyes in place to dimension, can this be acomplished with them in the way?Mike
I used 3/4" copper pipe and two pair of "Vicegrip" pliers for each section. I highly recommend using "Gorilla Brand" duct tape.
It's heavier, thicker and tackier than other tapes. Regular duct tapes were a waste of time.
Ragards
It is also been a pain when rolling the skins. try to get some help and you really need to press down on the table top when you are rolling....
Thanks for re-posting that, Dan. I've got some rolling to do soon and I couldn't find your original post.
When you taped up the skin to the pipe, you didn't tape it right at the edge of the metal, did you?
Could that have been from using a 1/2" pipe?
