Old 10-03-2010, 06:44 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Default Nine puppies...all Labs
I had hoped to go to LOE Saturday and pick up two Labs in Elk City on the way back. That fell through but I was told about two that needed transport from Lawrence Kansas. By the time I finally talked to the receiving end person, it was NINE Labs. Four 22-32 pound black Labs and the rest in the 10-15 pound range.
I got to Lawrence later than initially planned and it took longer to load. Finally that was done and I was getting ready to board and have the final Lab put on my lap when the larger black Lab to my right seemed to be growling at a tiny, shy yellow Lab. So we switched them (black Lab in the crate and the black Lab that would be on my lap) around. The two in that crate seemed to sleep the whole way back.
All went fine except that the growler threw up on me. I got them to KBJC (Denver area) and to the receiving end person. More later. I need to go play with my boy who was left alone all day.
On this mission, I noted that the woman in Lawrence had to babysit nine puppies for about two days. Perhaps more for two of them. That is amazing. Then I thought about the people who rescue the dogs, or find them homes and organize all the logistics of getting at risk dogs from point A to point B and finding homes for them.
All those folks are doing the hard work. I just transport by air. While I do enjoy it, I get to play a little with a lot of puppies and help in the process of getting them to a nice home, I came to realize that my role is minor.
As for the specifics, I am getting better although the hardest part still is knowing what size dog can fit in a crate. The weight and balance part is easy. Volume of puppies and allocation to crates is still a guess.
Today I had two of the smaller black Labs in my large crate in the baggage area. Then two small ones in a smaller crate on top of it. A largish crate in the passenger area (seat removed) held one larger black Lab and one small one and a medium crate on top of it held the last two small yellow Labs.
I heard that this was the smallest plane this group had used. In our defense, I will note that I got nine pups closer to a home. I went about 450 nm each way in three hours each way (OK, maybe a few minutes longer going west over Denver).
A 182 with all seats removed could haul more. But not as fast which means that it might not happen.
So while I am limited in size/weight of the pups I take, the RV does well enough.
Old 10-03-2010, 06:55 PM
rjtjrt rjtjrt is offline
Well done Ron. It is a good thing that you just did.
Respect.
John
Old 10-03-2010, 10:48 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Thumbs up "Lab Air"
Way to go, Ron. You did a great job in transporting those Labrador Retrievers. I have flown several Boston Terriers and the Boston Terrier rescue folks have nicknamed me "Boston Air" so you should be nicknamed "Lab Air" for this transport.
Someday we will have a fly-in for all RV pilots who have flown or who are interested in flying animal rescues. I've enjoyed flying for 26 years; flying PnP flights has given me new purpose in flying. It's hard to describe the good feeling you have from knowing the little guys in back will have a new home soon. Friday I flew two Boston Terriers, and one had been suffering from a dislocated hip for some time. The rescuer took it straight to a vet from the airport.
I won't say flying animal rescues is for every pilot, but it's obvious you enjoy it, Ron. Keep up the good work.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 10-03-2010, 11:46 PM
Snowflake's Avatar
Nice! You should be taking photos of these flights... I'd love to see what they all look like packed in there.
Rob Prior
Old 10-04-2010, 04:21 PM
Ron Lee's Avatar
Here are pics showing the crates as they were Yesterday. The first shows the baggage area crates. On the bottom is a Petmate large crate and a small crate on top. If you can support it another small crate could go on the bottom large crate. My ELT is mounted in the middle of the aft area and eats up room that could be used to position the lower crate better...so I may move the ELT.
The passenger side crates are shown below. The bottom crate has a top load door. On top of it is a Petmate medium crate. Passenger side stick is removed.
The configuration immediately above does eat up a lot of space by the flap handle. What I may do is put a medium crate down first then the larger one on top. Judicious use of bungee cords is appropriate. I am considering not using the crate with lots of holes. Too likely for liquid accidents to get out of the crate into the plane.
Old 01-24-2011, 01:54 PM
bkthomps bkthomps is offline
why not order up some angle/sheet aluminum and build in a custom sized holder?
Old 01-24-2011, 04:28 PM
Ron Lee's Avatar
I am not sure that it would be better than what I am using now. Might be...or not.
I did get rid of the crate with beaucoup holes. I don't see any more requests for multi-puppy flights now. Maybe it is a summertime need.
