Craig
Tru Trak has a service bulletin that addresses the possibility that the servo arm retaining screw might come loose. They will send you a bracket for free that will fix the problem.
My roll servo screw retainer was no problem. My pitch servo retainer had a clearance problem with the bracket that the servo is mounted on. Here is a picture to show the interference:
I will grind an arc in the servo mounting bracket to clear the screw retainer bracket.
