I just went over 10 hrs in my fly-off, so decided to do my first "cross-country" today. Flew to Kingman, AZ and shut down for about 15 min (looking for a diet coke) and the hopped in to return home. I have a Lyc IO-360 and have heard all the stories about hot starts but had no trouble starting mine. It did however seem to be running very rough at or near idle. The run-up and mag check was normal (ran smooth at 1700 rpm). Although a little nervous about the takeoff, all went well and I returned home safely. Once on the ground again the engine idled normally. I assume the roughness had something to do with the engine already being warm/hot. Can anyone tell me if this is normal and what the cause might be?
