Fuselage Parts Locator Cross Reference
Mich48041
Friend
I kept the fuselage parts together in their respective sub-kits to make the parts easier to find. But it was a hassle trying to find a part number in the packing list because they are not in alphabetical order. So I created the cross reference attached below to make it easier to locate parts. I hope this helps others. Joe Gores
12 PLANS FUSELAGE PLANS/MANUAL , MISC
AA6-063X3/4X3/4X6 ALUM ANGLE EF-403 ,SUB-KIT #10
AA6-125X3/4X3/4X92 . 5 ALUM ANGLE ,SUB-KIT #10
AN257-P2X18 HINGE X 18" ,SUB-KIT #9
AN257-P3X6' HINGE X 6' ,SUB-KIT #10
AS3-020X17/32X24 ALUM STRIP ,SUB-KIT #9
ATO-032X1/4X111 COIL SOFT ALUM TUBE COIL ,SUB-KIT #7
ATO-035X3/8X8' SOFT ALUM TUBE COIL ,SUB-KIT #7
ES 40105 FUEL PUMP RV-12 ONLY ,SUB-KIT #7
F-1017C BUNDLE 4 per SEAT BELT ATTACH LUG ,SUB-KIT #5
F-1086 VENT BRACKET ,SUB-KIT #5
F-1087 VENT SLIDE ,SUB-KIT #5
F-1201A FIREWALL TOP , MISC
F-1201B FIREWALL SHELF SUB-KIT #1
F-1201C FIREWALL BOTTOM SUB-KIT #1
F-1201E-L OIL TANK SIDE BRACKET ,SUB-KIT #7
F-1201E-R OIL TANK SIDE BRACKET ,SUB-KIT #7
F-1201F BATTERY MOUNT BRACE ,SUB-KIT #5
F-1201G OIL RESERVOIR BRACE ,SUB-KIT #5
F-1201H UPPER FWD FUSE DBLER ,SUB-KIT #8
F-1201Q BATTERY MOUNT ANGLE ,SUB-KIT #9
F-1201R ANTENNA SHELF ,SUB-KIT #5
F-1202A {RV-12F INV} 12 FUSE KIT INV COUNT , MISC
F-1202B PANEL BASE SUB-KIT #1
F-1202D PANEL ATTACH STRIP ,SUB-KIT #3
F-1202E-L BLKHD.SIDE CHANNEL ,SUB-KIT #9
F-1202E-R BLKHD SIDE CHANNEL ,SUB-KIT #9
F-1202F BULKHEAD ,SUB-KIT #8
F-1202H-L CANOPY RIB ,SUB-KIT #4
F-1202H-R CANOPY RIB ,SUB-KIT #4
F-1202J INST.STACK ANGLE ,SUB-KIT #8
F-1202K INST.STACK SUPPORT ,SUB-KIT #7
F-1202M CANOPY ATTACH DOUBLER ,SUB-KIT #5
F-1202N-L FWDSKIN STIFFENER ,SUB-KIT #9
F-1202N-R FWDSKIN STIFFENER ,SUB-KIT #9
F-1202T INST PANEL LEFT D-180 SUB-KIT #2
F-1202U INST.PANEL RHT.MAPBOX SUB-KIT #2
F-1203A BULKHEAD SUB-KIT #1
F-1203B BULKHEAD FLANGE ,SUB-KIT #7
F-1203D STUB SPAR RECEP SUPRT ,SUB-KIT #2
F-1203E BULKHEAD DOUBLER ,SUB-KIT #8
F-1203G-L BULKHEAD SIDE CHANNEL ,SUB-KIT #9
F-1203G-R BULKHEAD SIDE CHANNEL ,SUB-KIT #9
F-1203J BULKHEAD DOUBLER SUB-KIT #2
F-1204 CENTER SECT.ASSEMBLY , MISC
F-1204CL-L FWD BLKHD SIDE ASSY. ,SUB-KIT #4
F-1204CL-R FWD BLKHD SIDE ASSY ,SUB-KIT #4
F-1204D CNTR.SECT,AFT BULKHD SUB-KIT #1
F-1204F-L AFT SIDE BULKHEAD ,SUB-KIT #9
F-1204F-R AFT SIDE BULK HEAD ,SUB-KIT #9
F-1204H BUKLHEAD CAP ,SUB-KIT #6
F-1204P SKIN ATTACH FLANGE ,SUB-KIT #3
F-1204T SKIN STIFFENER ,SUB-KIT #9
F-1204Z BOTTOM STIFFENER ,SUB-KIT #8
F-1205A MID FUSE BRACE ,SUB-KIT #8
F-1205B ROLL BAR ATTACH PLATE ,SUB-KIT #5
F-1205C FUSE BRACE CLOSEOUT ,SUB-KIT #8
F-1206A BULKHEAD SUB-KIT #1
F-1206B REAR SPAR RECEPT SPR T ,SUB-KIT #5
F-1206F BEARING BRACKET BRACE ,SUB-KIT #7
F-1206G-L BAGGAGE RIB SUB-KIT #2
F-1206G-R BAGGAGE RIB SUB-KIT #2
F-1206H-L BAGGAGE RIB SUB-KIT #2
F-1206H-R BAGGAGE RI B SUB-KIT #2
F-1207A BAGGAGE BULKHEAD SUB-KIT #2
F-1207B BAGGAGE BULKHEAD SUB-KIT #2
F-1207C BAGGAGE BULKHEAD SUB-KIT #1
F-1207D-L BAGGAGE BLKHD CHANNEL ,SUB-KIT #8
F-1207D-R BAGGAGE BLKHD CHANNEL ,SUB-KIT #8
F-1207E SHOULDER STRAP LUG ,SUB-KIT #5
F-1207J ATTACH ANGLE ,SUB-KIT #9
F-1207K BRACE ANGLE ,SUB-KIT #9
F-1212-L STEP RIB SUB-KIT #2
F-1212-R STEP RIB SUB-KIT #2
F-1213-L STEP FLOOR SUB-KIT #2
F-1213-R STEP FLOOR SUB-KIT #2
F-1215-L SEAT RIB ,SUB-KIT #4
F-1215-R SEAT RIB ,SUB-KIT #4
F-1216 SEAT BELT ATTACH LUG ,SUB-KIT #5
F-1217A-L TUNNEL RIB SUB-KIT #2
F-1217A-R TUNNEL RIB SUB-KIT #2
F-1218 FLAPERON MIXER BRACKT ,SUB-KIT #7
F-1219 FLAPERON MIXER ARM ,SUB-KIT #9
F-1220A FORWARD INTERCOSTAL ,SUB-KIT #5
F-1220B AFT INTERCOSTAL ,SUB-KIT #5
F-1221-L BAGGAGE RIB SUB-KIT #2
F-1221-R BAGGAGE RIB SUB-KIT #2
F-1222-L BAGGAGE RIB SUB-KIT #2
F-1222-R BAGGAGE RIB SUB-KIT #2
F-1223-L BAGGAGE RIB SUB-KIT #2
F-1223-R BAGGAGE RIB SUB-KIT #2
F-1224-L BAGGAGE FLOOR ,SUB-KIT #2
F-1224-R BAGGAGE FLOOR ,SUB-KIT #2
F-1225-L SEAT FLOOR ,SUB-KIT #2
F-1225-R SEAT FLOOR ,SUB-KIT #2
F-1226-L SEAT RAMP FLOOR ,SUB-KIT #7
F-1226-R SEAT RAMP FLOOR ,SUB-KIT #7
F-1231A-AL ROLL BAR FRAME , MISC
F-1231A-AR ROLL BAR FRAME , MISC
F-1231A-FL ROLL BAR FRAME , MISC
F-1231A-FR ROLL BAR FRAME , MISC
F-1231B OUTBD ROLL BAR STRAP ,SUB-KIT #10
F-1231C INBD ROLL BAR STRAP ,SUB-KIT #10
F-1231D ROLL BAR BASE ,SUB-KIT #6
F-1231E ROLL BAR SPLICE PLATE ,SUB-KIT #5
F-1232A ROLL BAR BRACE ,SUB-KIT #8
F-1232B ROLL BAR BRACE BRCKT ,SUB-KIT #5
F-1233B-L CONTR OL COLUMN MOUNT ,SUB-KIT #6
F-1233B-R CO NTROL COLUMN MOUNT ,SUB-KIT #6
F-1234-L CANOPY DECK ,SUB-KIT #8
F-1234-R CANOPY DECK ,SUB-KIT #8
F-1235A Rudder Pedal Block, Misc
F-1235B Rudder Pedal Block, Misc
F-1236 STEP ATTACHMENT ANGLE ,SUB-KIT #9
F-1237A SEATBACK SUB-KIT #1
F-1237BD SEATBACK ANGLE ,SUB-KIT #9
F-1237C-L SEATBACK ANGLE ,SUB-KIT #9
F-1237C-R SEATBACK ANGLE ,SUB-KIT #9
F-1237G SEATBACK BRACE ,SUB-KIT #9
F-1240 UP PER FWD FUSE SKIN , MISC
F-1248-L ARM REST ,SUB-KIT #8
F-1248-R ARM REST ,SUB-KIT #8
F-1250 PULLEY BRACKET ,SUB-KIT #5
F-1251 NUTPLATE BRACKET ,SUB-KIT #9
F-1253 SEAT FLOOR SUPPORT ,SUB-KIT #8
F-1254-L SUPPORT FRAME ,SUB-KIT #8
F-1254-R SUPPORT FRAM E ,SUB-KIT #8
F-1256 SKIN STIFFENER ,SUB-KIT #9
F-1257 RUDR.PED.SUPRT.CHANEL ,SUB-KIT #9
F-1267A CROTCH STRAP BRACKET ,SUB-KIT #5
F-1267B CROTCH STRAP BRACKET ,SUB-KIT #5
F-1268 DOUBLER ,SUB-KIT #2
F-1270 FUSELAGE SIDE SKIN , MISC
F-1271-L FWD FUSE CORNER SKIN ,SUB-KIT #3
F-1271-R FWD FUSE CORNER SKIN ,SUB-KIT #3
F-1272 FWD FUSE FLOOR SKIN ,SUB-KIT #2
F-1273-L BAGGAGE CORNER SKIN ,SUB-KIT #3
F-1273-R BAGGAGE CORNER SKIN ,SUB-KIT #3
F-1274-L FUSE CORNER SKIN ,SUB-KIT #3
F-1274-R FUSE CORNER SKIN ,SUB-KIT #3
F-1275A F USE CORNER SKIN ,SUB-KIT #7
F-1275B F USE CORNER SKIN ,SUB-KIT #7
F-1275C FUSELAGE CORNER SKIN ,SUB-KIT #7
F-1275D FUSELAGE CORNER SKIN ,SUB-KIT #7
F-1275E FUSELAGE CORNER SKIN ,SUB-KIT #7
F-1275F FUSELAGE CORNER SKIN ,SUB-KIT #7
F-1276 BOTTOM SKIN , MISC
F-1277A AFT WINDOW , MISC
F-1277-L FWD TURTLE DECK SKIN , MISC
F-1277-R FWD TURTLE DECK SKIN , MISC
F-1288 COOLER STIFFENER ,SUB-KIT #9
GAS-5 GASCOLATOR 117 MICRON ,SUB-KIT #7
MAP BOX KIT PANEL MOUNT ALL ACFT , MISC
PT-062X1/4X15' HI PRES BRAKE HOSE ,SUB-KIT #7
WD-1204-PC ENGINE MOUNT BRACKET ,SUB-KIT #6
WD-1206-PC RUDDER PEDAL , MISC
WD-1209-PC BRAKE PEDAL ,SUB-KIT #6
WD-1210-PC CONTROL COLUMN , MISC
WD-1211-L-PC BRAKE PED TORQUE TUBE ,SUB-KIT #5
WD-1211-R-PC BRAKE PED TORQUE TUBE ,SUB-KIT #5
WD-1233-L STEP LEFT SIDE , MISC
WD-1233-R STEP RIGHT SIDE , MISC
Joe Gores
Fuselage Parts Cross Reference List
Joe, this will be very helpful. I too kept my parts in groups by kit #, but I know not everything goes into building following the subkit #s. Your cross reference list will be very useful. thanks! Scott
I did that for the tail and found it utterly frustrating and counter-productive. For the wings I changed it up. First I got the plans in advance and read them several times. When I got the kit, I put all the parts by section (of the plans) into plastic, covered containers and labeled them "section 13, 14, etc...." I needed one extra container for "extra parts that I couldn't yet find in the plans. It has been working perfectly! Now I can take a container with me when I feel like doing a little deburring or drilling while on the road too. I find that I become much more familiar with the parts and how they go together. Also, I work on parts that fit together at all times.
Catalogue
Mitch anyway you can make that list avaiible for us to print out at all?
Sure would be Very Handy!
Select, Copy, Paste, Save, & Print
Mitch anyway you can make that list available for us to print out at all?
SELECT the test by clicking and holding the left mouse button and dragging it over the desired text.
Right click the selection and click COPY (or CTRL-C)
Open your word processing or spreadsheet program and right click the document and click PASTE (or CTRL-V)
SAVE the document. (CTRL-S)
Click FILE, PRINT
Joe Gores
List
Click FILE, PRINT
Joe Gores
Thanks very much
I'm with 649PF. i can recommend putting all the bits for each plan section in one box. Strip the blue plastic, write the part number on each part in pen. You get to know the shape of parts as you match them to the plans to work out which section they belong to. Its great to see the boxes disappear, and if you are in the mood and set up for edge finishing and priming, you can work ahead. Have fun!
