philcam
I have the Craftsman Professional 25 gal. Air Compressor, 1.8 hp. It is this model here:
http://www.sears.com/shc/s/p_10153_...&+Air+Tools&sName=Air+Compressors+&+Inflators
Twice in the past month, the pressure regulator valve has failed. First it was the original Sears one that came on the tank and the second one was a Kobalt brand from Lowe's.
It seems like the o-rings are getting blown out. When the tank starts building pressure, air is leaking out around the knob that adjusts the pressure. This causes the pump to run constantly to keep the pressure in the tank up.
I can't understand why this part keeps failing. I've had this compressor for almost two years. Am I doing something wrong, or should I be looking at something else that is causing the part to break?
Thanks!
Phil
Thanks!
Phil
