Anyone installed either of these autopilots in an RV10? How do you like them? Have altitude hold feature? How does that work? Do these tie into the elevator trim servo that Van's uses?
If you will use the "Search" button at the top of this page you will find scads of information that will answer your questions. The autopilots should work equally well in any model of RV.
Try individual searches using "Trio" or "EZ Pilot" or "TruTrak". I just tried it and it came back with many dozens of recent posts about these systems.
