Soft AN426AD4-5's
boom3
With my fuselage I received at least 3 bags of non AD rivets.(at least I think) I found them while back riveting my firewall and said "What the heck? That was soft!"
The three bags are labeled AN426AD4-5.
None of these rivets have a center punch dot and all say "OIDC" on the top with no other markings.
Will these be used for anything? Did Van's just bag the wrong ones? When I say soft I mean they set easier than AN426AD3-5's. It was very obvious.
Thanks!
Bag 'em....
Thanks!
Keep 'em for use in fiberglass parts, but put them in a big red bag!
No dimple, then they are NOT "AD" grade....
If you used any, take them out and replace them, but it sounds like you have already.
Sounds like a mis-label to me....:(
gil A
The oidc is a manufac stamp. No dimple, you have A rivets, used usually in non structural areas. (pencil holder etc) :eek: Definetly a mis-lable.
Van's isn't sure why I ended up with them and is sending replacements.
If you recently received a kit you might double check in case you received some.(I got my fuse kit on Nov 1) I'm sure glad I couldn't squeeze everything on my firewall because I would have never noticed. When I switched to backriveting, it was very obvious.
